Thread: Rear brake pads - replacing
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Rear brake pads - replacing
    #21
    Feb 2014
    Leicestershire
    19 Post(s)
    A couple of people on gumtree will come and hook up VCDS for 30quid.
    Can someone help me confirm the disc/pad combo?
    Can I confirm the right size from chassis number or is model and year enough?
    A4 B8 58 plate Avant SE TDI 2.0 143z
    Googleing seems to suggest they are 300mm dia 1m thick solid disc
  2. Re: Rear brake pads - replacing
    #22
    Nov 2013
    Cumbria
    Quote Originally Posted by Alex jb View Post
    There are several sizes - you need to measure the disc size which will give you pad size as well. Rears are solid.
    I've gone for Pagid discs and pads on the front and must say I'm not impressed (noisy and poor stopping performance when hot). Saying that, I doubt you'll noticed if just doing rears.
    Once you've changed pads use VCDS to alter pad thickness for parking brake.
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  3. Re: Rear brake pads - replacing
    #23
    Feb 2014
    Leicestershire
    19 Post(s)
    I thought VCDS a was needed during the change to hold off the park brake?
  4. Re: Rear brake pads - replacing
    #24
    Sep 2008
    Kent
    Quick question: Do the rear pistons simply press back in or do they need winding in? I had the caliper off (after using VCDS with a battery charger connected) and the piston wouldn't move while trying to press it in?
  5. Re: Rear brake pads - replacing
    #25
    Nov 2013
    Cumbria
    Quote Originally Posted by Lemonslap View Post
    They are wind ins - do not push in otherwise you'll damage the thread.
    Clockwise wind in.
  6. Re: Rear brake pads - replacing
    #26
    Sep 2008
    Kent
    Quote Originally Posted by b206 View Post
    Clockwise wind in.
    Thanks mate, thought so! The 3 prong windback adaptor turned up today. The service manual I have states to push them back only...
  7. Re: Rear brake pads - replacing
    #27
    Sep 2008
    Kent
    So having completed the rear brakes (and needing to cut both discs off), it turns out the brake calipers are just push in and don't require winding.
    I also noticed one of my shocks is leaking.....
  8. Re: Rear brake pads - replacing
    #28
    Feb 2014
    Leicestershire
    19 Post(s)
    Cut the discs off?!
    What happened there?
  9. Re: Rear brake pads - replacing
    #29
    Aug 2011
    Meath
    Push in? What car are you talking about?
  10. Re: Rear brake pads - replacing
    #30
    Nov 2013
    Cumbria
    If you've just pushed them back without winding them in you've knackered something. Rear calipers on ALL cars with a handbrake need winding back - its how the mechanism works. If you park on a hill, you may find your car at the bottom when you get back.
    Cutting discs off sounds a bit extreme as well!
  1. Replacing rear brake pads
    By Will3001 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-11-2014, 06:54 PM
  2. Right.. Rear Brake Pads need replacing...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2011, 09:06 AM
  3. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  4. Replacing rear brake disks and pads
    By tatham in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2008, 10:11 PM
  5. Replacing rear brake pads on passat B6
    By PNS2007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2008, 10:10 PM
