Thread: Question; noise from wheel?
Results 1 to 8 of 8
  1. Question; noise from wheel?
    Feb 2015
    Pool Cornwall
    I have a whirring noise which seems as if it's coming from left front area. It becomes prominent at around 40mph, and doesn't seem revs related. I've looked around at the forums here and it might point to a wheel bearing. I'm really looking for a conformation or any other ideas of what this might be.
    Thanks for your time.
    Mark
    PS What does a noisy dif sound like?
  2. Re: Question; noise from wheel?
    Pembrokeshire
    22 Post(s)
    this is usually a wheel bearing. does the noise come and go as you steer round bends. other possibilities would be a tyre. a diff makes noise from the gearbox rather than a side. what car have you got and year etc....
  3. Re: Question; noise from wheel?
    Feb 2015
    Pool Cornwall
    Good morning. Thank you for your quick reply.
    I haven't noticed if the sound comes and goes when cornering, but shall monitor that now. The tyre seems to be fine and the noise is rather from the left side as opposed to more central. She is a 2003 S4 V8 4.2, approaching 144,000.
    One other question. Am I still safe to drive, if so are there recommended speeds that I should adhere to?
  4. Re: Question; noise from wheel?
    Pembrokeshire
    22 Post(s)
    can't say if you are safe to drive or not. you are if nothing happens, but if it is a bearing and it lock up or disintegrates, then its not safe. more than likely ok for a bit though.
  5. Re: Question; noise from wheel?
    Feb 2015
    Pool Cornwall
    ok, thanks for that. Is it a big job? I mean time wise. 1 hour, 2 hours?
    Audi S4 4.2 V8 2003 144,000 miles
  6. Re: Question; noise from wheel?
    Pembrokeshire
    22 Post(s)
    an hour in a workshop but you will need a press. a bit more if the top pinch bolt is stuck.
  7. Re: Question; noise from wheel?
    Feb 2015
    Pool Cornwall
    Great, thank you very much indeed for your advice. I feel a lot better about it now.
    0 2 0
  8. Re: Question; noise from wheel?
    Feb 2015
    Pool Cornwall
    Hi all,
    Just for the record, it was indeed a bearing. Almost £200 though!
    Thanks to Zollaf for your help.
    1 1 0
  1. wheel question
    By dneilom in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-10-2013, 09:30 PM
  2. Wheel question?
    By kennyb636 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-01-2011, 04:16 PM
  3. Another wheel question
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2010, 08:56 PM
  4. Steering wheel question
    By JPJ10 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-05-2008, 03:14 PM
  5. Wheel Question
    By cb1 in forum Audi A3 - Archive Topics
    Last Post: 21-02-2008, 07:00 PM
