Thread: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    Mar 2015
    Surrey
    Hi Guys,
    I am new on here. I have a 2007 Audi A4 2.0 TDI with just over 100k miles on it. On long journeys that take more than 3 hours, the car goes into Limp mode, the MIL turns on and the Glo Plug light illuminates. If i let the car sit for a while, then it comes out of limp mode and everything works fine. Strange thing is that it never happens on journeys under 2hrs long for some strange reason. I've connected up VAG-COM and read the codes and 4 error codes exist on the Engine module. the codes are:
    • P0234 Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    • P0113 Intake Air Temp. Sensor (G42): Signal too High
    • P0238 Manifold Pressure / Boost Sensor (G31): Signal too High
    • P0243 Solenoid Valve for Boost Pressure Control (N75): Malfunction
    Can this be 4 seperate issues or could it be one issue causing 4 different codes? Any idea what to look at?
    Any advice would be greatly appreciated.
  2. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    The N75 valve controls the boost. The Variable vanes at the turbo react to what vacuum it recieves from the valve. Check contacts at n75 and check for sticking mechanism at turbo.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    108 Post(s)
    1816 Post(s)
    There are three common possibilities for the limp mode from the over-boost situation, a clogged up turbo (by far THE most common reason), an over sensitive Manifold Absolute Pressure sensor (VAG called it a Thrust sensor) and a sticking N75 valve. Interestingly the Thrust sensor is the MAP (G31) sensor AND the Intake temp (G42) sensor combined which does suggest that changing the Thrust sensor first would be a good decision if no skilled mechanics were available. If this fails to stop all of these codes, then some deeper investigation would be required and a common problem I have seen is the wiring to the N75 valve breaking because it was routed badly from new. A proper VAG specialist would be able to carry out some direct Basic Settings and Outputs Tests to determine what is going on without any trouble or throwing parts at it will nilly.
  4. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    Mar 2015
    Surrey
    Thanks for the replies. Considering the mileage and age of the car I am considering changing both the N75 valve and the MAP sensor. Are these components easily accessible? Is the MAP sensor just connected to the intake pipe? and where will the N75 valve be and is there any special procedure to replace the N75 valve? is it just matter of removing the hose clamps and replacing? Any pictures of the location for the N75 valve? The car is 2007 Audi A4 2.0 Cabriolet
  5. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    108 Post(s)
    1816 Post(s)
    I would say from experience that there is only a 1% chance of a new Thrust sensor or N75 valve curing the overboost problem.
    On the BPW and BRC engine, the Thrust sensor is on the plastic charge air pipe as it runs across the back of the firewall after taking a 90 degree turn at the water bottle, check the brown/black earth wire for a break. The G31/G42 Thrust sensor and the N75 are not connected and if there was a supply fault to the N75, you would have V157, N144, clutch switch and glow plug problems. I would suspect that the only true fault code is
    16618 (P0234) 000564 - Boost Pressure Regulation: Limit Exceeded
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Boost Pressure too high (in Measuring Blocks 011 zones 2 and 3)
    Reduced Power Output (limp mode)
    Possible Causes
    Vacuum system leak or connection issue
    Boost Pressure Control Valve (N75) faulty
    Boost Pressure Sensor (G31) faulty
    Turbo Charger stuck/faulty
    Possible Solutions
    Check charge pressure control vacuum system for leaks
    Perform output test of N75 valve
    Perform Basic Setting in 011
    Perform charge air system pressure test
    Check boost control valve (N75)
    Check Manifold Absolute Pressure (Thrust) sensor (G31)
    Check turbocharger actuator travel and diaphragm for air leaks
    The other fault codes strike me as those devices being messed around with when the engine was running
  6. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    Mar 2015
    Surrey
    Thanks for the reply. Is there any particular reason why you would think changing the MAP and N75 would only likely have a 1% chance of curing the problem? considering they represent combined 50% of the possible causes.
  7. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    108 Post(s)
    1816 Post(s)
    Because I work on these cars all day every day (just taking the clutch out of a 2006 8E at the moment and just put the turbo back on a 2008 8K yesterday) and I hardly EVER buy thrust sensors or N75 valves for any VAG car, in fact I think the last N75 valve I bought was at least 2 years ago and the last thrust sensor was for a petrol engine, before that I can't remember. Every single time I get this fault code it is a sticky turbo vane ring/vanes. The other fault codes are the 1% hesitation for me but I suspect they are small red oily fish......
  8. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    May 2015
    Essex
    Hello newbie here sorry to jump in the post haven't got a clue how to post on here or where to post but I'm having vacuum trouble with my 04 plate a3 2.0 tdi it doesn't seem to boost up properly in 1st and 2nd gear just seems to hit a wall but if I ease off and on again it kicks in properly , experimentally I took off vacuum resivour pipe and it cured it for a while then I think it must have lost all vacuum and went limp I put resivour pipe back on and ten minutes later back to only being no good in 1st and 2nd any help would be much appreciated also at idle if I accelerate it only goes to a certain point just like in 1st and 2nd but if I go off and on accelerator again it will hit the guv'nor ?????? I'm lost any help greatly appreciated
  9. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    Feb 2020
    uk
    Sorry to resurrect an old thread, but I have the P0234 issue appearing on wife's BLB-engined A4 2.0 TDI. This ONLY happens though on a cold engine, never once its warm. Crasher any ideas what this might be please? I'm guessing the turbo will need cleaning properly regardless but could that particular issue be caused by a sticking actuator rod?
    Cheers in advance for any advice.
    Tel
  10. Re: 2007 Audi A4 2.0 TDI, Turbo Boost Related Issues
    108 Post(s)
    1816 Post(s)
    The rod sticks due to the carbon inside the turbo, for a while it may only do this when cold as when hot the turbo expands and the carbon fouling becomes less of a problem but it will eventually do it all the time.
  1. Replies: 12
    Last Post: 24-05-2017, 04:10 AM
  2. Question Audi A4 B6 1.9 TDI (Germany) - suspecting these are turbo-related
    By gos_prstenova in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2014, 07:01 PM
  3. 2007 A6 2.0 TDI - Boost?
    By PJB1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-11-2012, 01:15 PM
  4. Audi 2.7 TDi turbo issues ?
    By ruggedscot in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-11-2011, 10:16 PM
  5. Please Help Audi 80 TDi loosing turbo boost then cutting out
    By hawkeye1975 in forum 80 - 90
    Last Post: 20-08-2008, 06:30 PM
