Thread: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
  1. A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    Nov 2013
    leeds
    oil pressure low warning came on the display the other day when my girlfriend started the car and she reported lack of power to the point the engine stalled when she set off. In my absence she topped up the engine oil (it was low) and the car was fine for a couple of days. I drove the car yesterday and it was fine at first but after a while there was a definite lack of power as though the clutch hadn't fully disengaged, it felt just as it would if you drove without fully releasing the clutch but the pedal was back to it usual resting point. There has been no warnings on the display since the first time and the problem seems to be intermittent. Incidentally the cruise control stopped working a couple of weeks ago and i wondered if this could be related if it is a clutch problem?
    Is this likely to be a clutch or engine oil pressure problem?
    Any help or advise would be greatly appreciated , so thanks in advance.
    Pete
  2. Re: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    doctleodd Guest
    Has it used any oil since it was topped up. I'm thinking your rear crank seal might be leaking
    1 1 0
  3. Re: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    Pembrokeshire
    22 Post(s)
    i would agree with the newly helpful and polite doctleodd.
    1 1 0
  4. Re: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    Nov 2013
    leeds
    Thanks for the reply
    just checked the oil level and its just where it should be but it has lost a bit of oil in the last few months. If it is the crank seal are there any other tell tale signs to look out for and whats the damage ££££? The car is due a service but the oil looks clean that is in there
  5. Re: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    Nov 2013
    leeds
    ok, just started the car in nuetral and a grinding noise could be heard , put the clutch in and its ok let the clutch out and commence the grinding noise, ploom of smoke from the exaust and then the car stalled. Doesnt sound good but does sound expensive
  6. Re: A4 B7 1.9 avant power loss, clutch? engine oil pressure? help
    Pembrokeshire
    22 Post(s)
    that is indicative of a failed dmf. so thats gearbox out, new dmf, clutch and probably rear crank oil seal to be safe.
  1. Wanted Avant 1.8T sport AVJ engine lost oil pressure needed top end or full engine
    By Graham92 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2013, 11:58 AM
  2. Please Help clutch pedal pressure loss!!!
    By lauee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2011, 07:01 PM
  3. Please Help Loss of Oil Pressure
    By DropKickMurphy in forum Scirocco - Corrado
    Last Post: 07-09-2010, 02:30 PM
  4. Low oil Pressure - STOP! Loss of power
    By kunaalv in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2010, 06:32 PM
  5. Engine Damage from Oil pressure loss
    By mrhope2933 in forum Archive posts
    Last Post: 03-05-2007, 09:38 PM
