Thread: wheel hub issue
Results 1 to 10 of 17
  1. wheel hub issue
    Feb 2015
    luton
    I recently bought an Audi cabriolet year 2000, picked it up cheap and thought it would be a nice run about for the wife during summer the car itself is in very good condition,i was told when I bought the car the drivers side front wheel bearing was going to need changing simple fix (I thought) only when I got the car home and took off the wheel I found all four hubs had been welded up and ground then re drilled and fitted with 4 stud wheels so my question is what hubs can i use as doner, I don't want to go back to 5 stud as I will then have to replace the wheels also..trying to keep cost down.
  2. Re: wheel hub issue
    Mar 2013
    Virginia Co Cavan Ireland
    Buddy I would be very very surprised if you could ever insure the car in that state, go back to 5 stud and scrap what's there. It's a bodge of the highest order buddy.
    Mick
    Mick
    99 Bora Tdi
  3. Re: wheel hub issue
    Aberdeen
    63 Post(s)
    The top left hole, looking through the brake disc, it looks like they have tapped the new hole onto an existing hole. This is not good. Remember that is all that is going to save you when you have to brake hard. Looks like you need new hubs, disks and wheels. Good opportunity to get the lot overhauled.
  4. Re: wheel hub issue
    Feb 2009
    Glasgow UK
    Wow
    Selling a car in that state, some people have no morals!
  5. Re: wheel hub issue
    Feb 2015
    luton
    I agree total overhaul, I have been looking for the same model via breakers but so far come up with zero. Buying new is not an option as the cost complete with new wheels would make the car none
    viable. Waiting for a response from audi to see if A4 hubs from same year are an option if not it will be a scrapped project.
  6. Re: wheel hub issue
    Aberdeen
    63 Post(s)
    What model is the car. There may be options from vw or skoda for parts.
  7. Re: wheel hub issue
    Mar 2013
    Should be y g s same as an a4 or a6 from t he same era.
    Mick
    Mick
    99 Bora Tdi
  8. Re: wheel hub issue
    Feb 2015
    luton
    Model is as in photo I made of car 1.8 cab year 2000..I think wheels are A4
  9. Re: wheel hub issue
    Mar 2013
    If the wheels are 4 stud they are not a4, all a4s are 5 stud, yours should have all the same suspension gear as a 96-01 a4 so should be no problem getting the bits you need.
    Mick
    Mick
    99 Bora Tdi
  10. Re: wheel hub issue
    Aug 2011
    Meath
    Look on gumtree or pre-loved for someone selling or breaking an A4/Passat, crashed or one with engine troubles. I assume you have a good grasp of the spanner because it will take you a couple of days. Before doing anything contact the seller and if needs be the police. This moron could have wiped out you, your family or another family.
  1. Wheel bolt/hub stripped.
    By vwhighline in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-06-2013, 01:39 PM
  2. Attention Alloy wheel seized to hub!
    By legendamongus in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-11-2010, 01:10 AM
  3. rear wheel hub
    By avishaym in forum 80 - 90
    Last Post: 10-08-2010, 01:27 PM
  4. Question Wheel Bearing/ Hub ???
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2010, 01:09 PM
  5. Please Help Breather or wheel hub?
    By Fork86 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2009, 08:20 PM
