Thread: Engine strip inspect and possible rebuild.
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. Re: Engine strip inspect and possible rebuild.
    #21
    Aug 2011
    Meath
    Jammy man, Still it's nice to have a new engine in an old motor for a f*&^%£*g tenner too!
  2. Re: Engine strip inspect and possible rebuild.
    #22
    Jan 2015
    Southampton
    I'm still stripping right down and all gaskets and bearings changed. And none of them are plus size either
  3. Re: Engine strip inspect and possible rebuild.
    #23
    Jan 2015
    Southampton
    Getting there slowly. Will finish degreasing the block tomorrow then give it a lick of paint ready for the rebuild.
  4. Engine strip inspect and possible rebuild.
    #24
    Jan 2015
    Southampton
    Managed to source some main journey shells. Which I'm collecting tomorrow. Started fitting parts tonight and cleaned the. Block a little more before hand.
    So far I have fitted:
    the middle shaft with new seals and fixed into block.
    Fitted distributor with new seals aligned to timing points and fitted to block.
    Fitted new water pump and thermostat
    Fitted oil filter and cooler housing.
    Tomorrow I'll be fitting:
    crank shaft
    Pistons
    New shells all over
    New oil pump
    Sump and new gasket
    Hopefully fit.
    Cylinder head and get the engine timed up and ready to install.
  5. Re: Engine strip inspect and possible rebuild.
    #25
    Jan 2015
    Southampton
    Main journal shells arrived today. Will be slapping her together tomorrow afternoon over a cold cider and a BBQ
  6. Re: Engine strip inspect and possible rebuild.
    #26
    Jan 2015
    Southampton
    Got the main journal shells in at lunch time will be fitting the pistons and new big end shells this evening then just head alternator and starter motor and away she goes
    0 2 0
  7. Re: Engine strip inspect and possible rebuild.
    #27
    Jan 2015
    Southampton
    Old engine out and clank and pistons in new block.
    2 1 0
  8. Re: Engine strip inspect and possible rebuild.
    #28
    Jan 2015
    Southampton
    I put the short block in last night. Was a complete a****ole to line up with the gearbox. But got there with help from a friend.
    Head on and lined up. Was getting very dark at this point.
    Head is on times and a few things wired up.
    I got the alternator on today and water pump pulley torqued on as well as the last of the wiring, pipes and oiled up. Just got one water flange on the right hand side of the head to replace as my dad through it out during the rebuild . But ran her for 20 secs to make sure she runs and she sounds lovely
    1 1 0
  9. Re: Engine strip inspect and possible rebuild.
    #29
    Jan 2015
    Southampton
    Damn the rain has hit before I could finish it. Tomorrow it is then
  10. Re: Engine strip inspect and possible rebuild.
    #30
    Aug 2011
    Meath
    Quote Originally Posted by patrick_c99 View Post
    You won't rust man, get on with it!
  1. Please Help Help needed on Door Lock strip down and rebuild
    By rosso rocket in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2012, 05:30 PM
  2. Clutch rattle = Gearbox strip and Rebuild
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-05-2011, 11:08 PM
  3. How to strip and rebuild a rear caliper
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-09-2009, 05:11 PM
  4. T4 Engine Rebuild
    By Harmergeddon in forum The Commercial Range
    Last Post: 29-09-2008, 09:13 AM
  5. Engine rebuild
    By BEAST O BODMIN in forum Chat - Anything with wheels
    Last Post: 13-03-2008, 11:43 PM
