Thread: P2279 Leak in Air Intake System - Faulty PCV Crankcase Vent?
  1. P2279 Leak in Air Intake System - Faulty PCV Crankcase Vent?
    Jan 2012
    London
    Hi all,
    Yesterday car went into limp mode, so I stopped and restarted. 100 yards up the road same again. Also noticed a strange sucking noise when engine under load.
    I have plugged in VCDS and can see P2279 error, Leak in Air Intake. I have looked and listened around engine as best I can and no real obvious air leak but no one around to rev engine!
    I have notice there is a bit of pressure if I open oil filler (like it wants to blow the oil cap off), also some fumes escaping.
    My initial thought is PCV valve located on top of engine (2.0 TDI 170 BHP BRD engine). This looks like it should be easy to change, there is one pipe that comes from it which is easy to disconnect, but not sure how to remove the valve itself? Any know how this is done. Is there a way to test valve?
    Also any other thoughts on cause?
  2. Re: P2279 Leak in Air Intake System - Faulty PCV Crankcase Vent?
    Apr 2017
    Hi there just curious did you ever sort this issue?
  1. Replies: 3
    Last Post: 16-10-2012, 09:30 AM
  2. crankcase vent valve
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-01-2012, 10:44 PM
  3. Crankcase vent system?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2011, 03:55 PM
  4. APR Tuned - 2.0 TDI Carbon Fiber Cold Air Intake System
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-07-2011, 07:24 PM
  5. Please Help tdi 130 mark 4 o2 plate turbo air intake pipe oil leak
    By homerj9 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 06:14 PM
