Thread: Problems starting from hot
  1. Problems starting from hot
    Aug 2011
    Riberac France
    I have a golf mk v tdi 2008. In June I had a new clutch and dmf fitted. Shortly afterwards I noticed a lot of vibration when starting from hot. This has got progressively worse to the point that its almost impossible to re-start immediately if the engine cuts out when hot. It does sound a bit like an exhaust problem but that's been eliminated. My garage suggested I took it to a vw main dealer. They have diagnosed a faulty clutch, dmf and starter motor. Another independent garage said it was the dmf.
    My garage who fitted the new clutch in June last year doesnt believe it could be that. Surely if the dmf was faulty then it would make a noise all the time, not just on starting when hot.
    Does anyone have any ideas on this or should I just get my garage to take out the clutch starter motor and check.
    the clutch was Sachs make so not a cheap one. It.s still under guarantee.
    Thanks.
  2. Thumbs up Re: Problems starting from hot
    Aug 2011
    Riberac France
    Quote Originally Posted by jonjono1 View Post
    Thanks.
    Surprisingly there were no relies to my thread posted a month ago. 'Why is the blue motion site so inactive?:Blush2::Blush2:
    Anyway maybe it will help someone with a similar problem if I tell you what happened.
    despite the VW dealer telling me i needed a new clutch/dmf and starter motor total cost almost €2500 euros, my independent mechanic working from home fitted a new Bosch starter motor total cost with fitting €300. Job done problem solved!
  1. Starting when hot and remote unlock problems
    By jackanory in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-04-2010, 11:49 PM
  2. Can't find part.. problems starting hot
    By Tomyblu in forum Golf MK3 - 1993 - 1999
    Last Post: 02-11-2008, 05:45 PM
  3. Please Help Tdi starting problems when hot
    By darrenssharan in forum Golf MK4 - 1999 - 2004
    Last Post: 02-07-2008, 06:07 PM
  4. 2000 POLO 1.0 Hot starting problems
    By sheffpolo in forum Polo - Derby - Lupo - Fox
    Last Post: 31-10-2007, 05:32 PM
  5. lupo hot starting problems
    By fastpart in forum Polo - Derby - Lupo - Fox
    Last Post: 08-10-2007, 01:26 PM
