Thread: No headlight, wipers or reverse lights
  1. No headlight, wipers or reverse lights
    Jan 2015
    Southampton
    Hey. I recently brought a mk2 1.8v gti digifant. After ripping out the immobiliser I now have a running car and dash.
    The heater works and so does the rear windows, and side lights but no dipped beams, main beams or wipers/washers.
    Also need a new bit that the dip stick clips into as mines snapped.
  2. Re: No headlight, wipers or reverse lights
    May 2007
    17 Post(s)
    Hello Patrick.
    Have you checked your headlamp fuses? Dip beam is F21,F22 & Main beam is F9, F10. Check the fuses aren't blown but also make sure that voltage is being supplied to the fuses.
    If no voltage is being supplied to the fuses, remove the lighting switch from the dash. Now check you have voltage on the black/yellow wire and with the headlamps switched on, check for voltage on the white/black wire. If the blk/yel has voltage but not the wht/blk then the lighting switch is faulty.
    Let us know what you find.
    Jim.
  3. Re: No headlight, wipers or reverse lights
    Jan 2015
    Southampton
    No power to the fuses. Went to test the switch and my tester ran out of batt. Will check it tomorrow on my day off. Got head gasket to do as well now
  4. Re: No headlight, wipers or reverse lights
    May 2007
    17 Post(s)
    I should have said in my last post that the black/yellow wire at the switch is an ignition supply, so check for voltage with the ignition switched on.
  1. Audi Headlight Wipers Problem (not washers)
    By volkswagen 1200 in forum Vehicular windows, Glazing and Tinting
    Last Post: 15-10-2014, 07:59 AM
  2. Help!!! No reverse lights
    By kevlar1908 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2014, 09:23 AM
  3. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  4. Adjusting window/headlight washers and wipers
    By royclark in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-05-2013, 01:23 PM
  5. Replies: 5
    Last Post: 24-05-2009, 11:57 AM
