Thread: How do i bleed the fuel system on a V6 tdi?
  1. Question How do i bleed the fuel system on a V6 tdi?
    Jan 2015
    warminster, uk
    Hello!!!!
    can anybody please instruct me in the correct way to bleed the fuel system on a 2000 Passat V6 tdi
    I bleed it and get it going, take it for a drive, runs sweet and strong, then next morning will not start, air in the feed pipe.
    any advice will be much appreciated!
  2. Re: How do i bleed the fuel system on a V6 tdi?
    It sounds like you have a air leak and fuel is leaking back to the tank and fuel pumps do not pump air very well. You need to inspect all the pipes and joints for the leak. The inner surface of the pipe can develope hair line cracks and cause a leak. You can spray wd 40 on the joints as you may spot the wd being sucked away. Why did you need to bleed the system originally.
    I assume this is an AKE engine and you need to tell me the VIN as they change how to bleed it.
    PM me your email address.
    Regards Peter
  1. How to bleed out air from the cooling system on a 1.9TDI?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 29-01-2019, 02:28 AM
  2. Question What is the best way to prime a 2.0 tdi fuel system after changing fuel filter?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2012, 09:40 PM
  3. trying to bleed water system on my 2.4 v6 petrol
    By scanny1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2012, 12:11 PM
  4. bleed screws in cooling system
    By chimo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2010, 09:28 PM
  5. air bleed screws in cooling system
    By chimo in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2010, 12:09 PM
