Thread: Parking sensors .... Vcds
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Parking sensors .... Vcds
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    9 Post(s)
    They are all the same... Now I think they are all gone
    Audi A6 Avant 2.7 TDi Quattro Le Mans..... xenon, 19" alloys, bluetooth phone, satnav
  2. Re: Parking sensors .... Vcds
    46 Post(s)
    Quote Originally Posted by poosnip View Post
    why?? did you look at the measuring blocks in module 76 as advised?? can't remember which group it is but they show you the distance they read, with nothing on front of them they read i think 255cm.
    edit - you already have threads on this issue??
    https://www.vwaudiforum.co.uk/forum/s...g-system-fault
    https://www.vwaudiforum.co.uk/forum/s...chace-and-Pain
    https://www.vwaudiforum.co.uk/forum/s...arking-sensors
  3. Re: Parking sensors .... Vcds
    Jun 2010
    9 Post(s)
    They all read 255. No changes if you walk in front or behind
  4. Re: Parking sensors .... Vcds
    May 2007
    17 Post(s)
    Maybe it's not a sensor that's faulty then. Maybe it's a wiring fault. I've had a few VWs with wiring behind the bumper chaffing to the metal crash bar. Each sensor has a common supply & earth so if one of those has been damaged none of the front sensors would work.
    Jim.
  5. Parking sensors .... Vcds
    Jun 2010
    9 Post(s)
    Used measuring bloCks ... I can say that the rear parking sensors are working ... They show a change on measuring blocks . and after doing the fingernail test, they are all ticking and I can hear the tick .....
    The fronts are dead .... No change on advanced measuring blocks and no ticking
    It could be a wiring fault, but non of the fronts show any sign of life
  6. Re: Parking sensors .... Vcds
    May 2007
    17 Post(s)
    None of them would if the voltage supply or earth wires were damaged. Those two wires are connected to each of the sensors so a fault with those wires would effect all the sensors.
  7. Re: Parking sensors .... Vcds
    #17
    Apr 2018
    Chesterfield,Derbyshire.
    Quote Originally Posted by Flash2 View Post
    Jim.
    Hi,Is the switch lit up all the time?Then when you put it in reverse you just get a constant annoying tone.
    I had the same problem last week when my washer pipe came apart and flooded the passenger footwell and under the seat of my VW Sharan. The reverse sensor module under the passenger seat was wet through. So l dried it out but still the same.Then l made alot of phone calls round scrapyards and found one on a ford galaxy with the same numbers.£15 l plugged it in and hey presto everything was back to normal. Hope this helps.Dbf5y.
  8. Re: Parking sensors .... Vcds
    #18
    May 2007
    17 Post(s)
    Quote Originally Posted by Dbf5y View Post
    If I had a pound for every time I've come across that fault on a Sharan.....I'd be about £3 better off
  1. Revers parking sensors or Parking Aid
    By oraab1 in forum Parts & Accessory Price Requests
    Last Post: 17-12-2014, 08:38 PM
  2. Passat 2006 - diagnose parking sensors with VCDS
    By xxxlogger in forum VCDS - Help Requests
    Last Post: 10-02-2014, 01:43 PM
  3. Replies: 6
    Last Post: 15-12-2013, 01:16 AM
  4. Parking sensors
    By Michael Maurice in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-09-2012, 10:35 PM
  5. parking sensors
    By nug402 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-08-2008, 05:55 AM
