Thread: Touran 2011 bluetooth
  1. Touran 2011 bluetooth
    Nov 2008
    Hi folks,
    Last year I bought from vw main dealer a Touran 1.6 se. I wasnt aware that although it reg is may 2011, it did not have bluetooth fitted standard. They told me I could have a tpk bury fitted but it wont stream music from phone.
    I would be greatfull if someone out there could point me in the direction where i might obtain a proper module and wiring kit to fit with Rcd 310 radio and steering wheel controls. Ive seen loads on the net but would rather take expert advice on type, fitting under seat etc, mic, any special programming with car etc. i live in Northants..
    Cheers folks and happy new year.
    ps. Sorry if this has already been trampled to death.
    Jeff
  2. Re: Touran 2011 bluetooth
    Oct 2011
    Redditch, worcestershire
    Hi
    There you have 2 examples. First one is a bit more expensive coz its the latest one, wit WiFi hotspot.
    http://pages.ebay.com/link/?nav=item...263325&alt=web
    Second one is cheaper and for you also will do the job. http://pages.ebay.com/link/?nav=item...245604&alt=web
    Both versions are with a BT music stream. Installation is quite easy. On the back of the radio is plug and play quadlock. Than you have to run all the wiring under the seat and mic by the mirror.
    Usually BT eorks without any codding but its good if you have VCDS to change the settings on it but it will work without it.
    Good luck
  3. Re: Touran 2011 bluetooth
    Nov 2008
    Cheers for the links Alex. Looking at the second link the item description is in German. The. Bottom line translated reads not working with RCD 310. Just my luck! I need to find a resonably priced kit that will work with full functionalty including steering wheel controls. Thanks for looking
  4. Re: Touran 2011 bluetooth
    Oct 2011
    I have this one in my mk6:
    http://pages.ebay.com/link/?nav=item...501086&alt=web
    I think it is the same seller as from the second link. In my car i can control all of the function from the steering wheel. I can access address book/dial via instrument cluster. It also supports BT music
  5. Re: Touran 2011 bluetooth
    Nov 2008
    Thanks mate, do you recon it will run with radio RC 310 blue screen version. Looking at the number it looks like the right part. Dont wish to keep bothering you but home management does not like me spending on frilly bits so its a one hit opportunity.. Haha
  6. Re: Touran 2011 bluetooth
    Oct 2011
    I tkink it works with your HU but to be 100% sure ask the seller.
  7. Re: Touran 2011 bluetooth
    Nov 2008
    Yep! Ive just done that, will post reply and subsequent result in due course. What a faff!
  8. Re: Touran 2011 bluetooth
    Sep 2019
    GB
    Just wondering how the OP got on with this? I know i5ts a couple of years old. I have the same scenario:
    VW Touran 2011, with steering wheel controls, RCD310, but NO Bluetooth module
    Would love to be able to determine the right BT module, so I can add Bluetooth functionality.
    Also - what does 'coding' mean in this context? Is that a DIY job, or is it more complicated than that?
    Thanks!!
    Sent from my SM-G973F using Tapatalk
  1. 2011 Touran front grill
    By ronecc in forum Touran - Sharan - Caravelle
    Last Post: 20-10-2014, 12:33 PM
  2. Westfalia Towbar Switch from B6 Passat Estate to 2011 Touran
    By cjdad76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2013, 07:11 PM
  3. 2011 touran fitting parking sensors
    By steve! in forum Touran - Sharan - Caravelle
    Last Post: 21-09-2012, 02:13 PM
  4. Adjusting lights for Mainland Europe (new 2011 Touran)
    By Chippy436 in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2011, 10:18 PM
  5. 2011 - Integrated Bluetooth Connectivity (9W7)
    By cullinp in forum Passat CC
    Last Post: 30-09-2010, 09:03 AM
