Thread: Replacing rear discs & pads
  1. Replacing rear discs & pads
    Oct 2014
    haworth, yorkshire
    On the A6 2.5 `53 plate when the rear discs and pads are replaced does the handbrake cable have to be slackened off prior to fitting and then readjusted or is it self adjusting? thanks keith
  2. Re: Replacing rear discs & pads
    Mar 2013
    Virginia Co Cavan Ireland
    There is a special tool for winding back the caliper as the handbrake works on the rear pads, they self adjust back out when you press the brake a few times.
    Mick
    Mick
    99 Bora Tdi
  3. Re: Replacing rear discs & pads
    36 Post(s)
    830 Post(s)
    It depends, sometimes you have to if the cable adjustment has been messed around with due to a faulty caliper that is replaced but generally, no. As Mick says you need a piston windback tool for that part.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  4. Re: Replacing rear discs & pads
    Oct 2014
    haworth, yorkshire
    thanks for the replies, spot on forum as usual.
  1. Rear discs & pads
    By Dave Elcome in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-07-2014, 06:52 PM
  2. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  3. Rear discs & pads change
    By northern kev in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2009, 10:33 PM
  4. Replacing rear discs and pads on a 97' TDI
    By bagseye in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 03:02 PM
  5. rear pads & discs
    By davidlandy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 09:32 PM
free web
stats
