Thread: 2.0 170 S-line Fan running all the time
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. 2.0 170 S-line Fan running all the time
    Jul 2014
    Up North
    Hello FOlks,
    A few months ago I noticed my cooling fan on the A6 was running constantly. As soon as I start the car up it runs, and then powers down when switching the car off. Occasionally it runs on for a few minutes when the car if off and locked.
    I contacted Audi, the car was still under warranty and only as 34k on it, they said this was normal with DPF etc. I have taken the car on two 70+mile trips at high revs in 4-5th gear and the fan is still running. I am starting to think there may be a cooling sensor fault? Anyone else have this issue?
    Thanks,
    IB
  2. Re: 2.0 170 S-line Fan running all the time
    46 Post(s)
    As its under warranty ask them to do a fault check as yh think something is wrong.
  3. Re: 2.0 170 S-line Fan running all the time
    Jul 2014
    Up North
    I would but I live on an Island and the nearest dealer is a day trip involving a ferry. As far as i know there is no garages on the island the VAGCOM. The dealer tells me this is normal, but surely a DPF regen wouldnt take two months?! I want to know if this is a normal DPF thing or if it is more likely a fault. Then I can send the car over armed with info.
  4. Re: 2.0 170 S-line Fan running all the time
    May 2010
    Ellesmere Port, England
    This is not normal, therefore you have a fault! What does the temp gauge say? If normal your probably correct with the sensor problem.
    Either way, without access to VagCom you need a scan. Your dealer cannot say there's nothing wrong as constant fan operation will ultimately wear it quicker until it fails. Insist they look into it and sort it out.
    Good luck & Merry Christmas!
    Audi A5 3.0L quattro Convertible
    2010 in Ibis White with lots of toys!
  5. Re: 2.0 170 S-line Fan running all the time
    Jul 2013
    76 Post(s)
    Have you checked that the AC is on, if so then this is why the fan is running.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: 2.0 170 S-line Fan running all the time
    Jul 2014
    Up North
    Temp gauge is perfect, just take a little longer to get up to temp with the fan being running all the time. Thanks for the replies, will hunt down a vag computer today. Tried with AC off, no change.
  7. Re: 2.0 170 S-line Fan running all the time
    Jul 2014
    Up North
    Where is the Temp switch on this engine?
  8. Re: 2.0 170 S-line Fan running all the time
    46 Post(s)
    Think it's been mentioned before, do a search.
  9. Re: 2.0 170 S-line Fan running all the time
    Aug 2014
    Newport, S Wales
    Had this fault on my caddy. Totally different I know, but it was because the external air temp was faulty.... Cost me £5 on eBay
  10. Re: 2.0 170 S-line Fan running all the time
    Sep 2008
    mostly in the garage
    Quote Originally Posted by Islandboay View Post
    Hello FOlks,
    Thanks,
    IB
    Not sure of its location on your vehicle, usually in a coolant hose somewhere........there is a radiator outlet temperature sensor that is used for fan operation. Failures are not uncommon on vag vehicles so might be a place to start.
  1. Replies: 29
    Last Post: 02-10-2013, 10:59 PM
  2. Fan running whole time!!
    By t111bul in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-11-2012, 01:13 PM
  3. Fan stays on most of the time
    By matt925 in forum Golf MK5 - 2004 - 2009
    Last Post: 25-09-2012, 04:45 PM
  4. Please Help a4 s line diesel manual 2010 plate fan staying on !! / a4 s line special addition spec ??
    By garry5510 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2012, 06:36 PM
  5. 1.8 fan on all the time
    By rob160 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2009, 10:30 PM
