Thread: 2.0 170 S-line Fan running all the time
Results 11 to 20 of 26
  1. Re: 2.0 170 S-line Fan running all the time
    Jul 2014
    Up North
    Turned out to be a faulty AC pressure/Temp sensor. Sensor -G395 IIRC. The one on the condeser.
    Thanks for the help regardless.
    2 0 0
  2. Re: 2.0 170 S-line Fan running all the time
    May 2010
    Ellesmere Port, England
    Glad you got it sorted, can be a real pain!
    Audi A5 3.0L quattro Convertible
    2010 in Ibis White with lots of toys!
  3. Re: 2.0 170 S-line Fan running all the time
    Jan 2014
    Southampton
    Quote Originally Posted by Islandboay View Post
    Hi, I know this was a while ago but mine is doing the same. How did you narrow it down? Did it show up as faulty in the VAGCOM scan?
  4. Re: 2.0 170 S-line Fan running all the time
    Mar 2017
    Rocheste UK
    I've got the same error on my car. Yes the error shows up in VCDS (00256). I also notice when you you look in advanced measuring values under engine you can pull some very useful measurements, like Fan1_rPs, Fan2_rPS and several other Fan_rClgDemXXX labels. These show what feature is demanding the cooling fans and at what duty cycle. On mine the one with AC in the name shows a 100% demand request and I have Fan1_rPs of 89.9%. So with a 00256 error and an AC fan demand, pretty clear that's the culprit.
    I'm doing this from memory as I don't have my VCDS session to hand. I'll check when I get the logs to hand.
  5. Re: 2.0 170 S-line Fan running all the time
    Mar 2017
    Kings Lynn Norfolk
    Hi,I had same problem on my 2.0 tdi got a new ac pressure/temp sensor two days ago fitted within 30mins only have to pull bumper out on near side slightly to access switch,hope you guys got it sorted ��
  6. Re: 2.0 170 S-line Fan running all the time
    Mar 2017
    Rocheste UK
    Found a screen capture I took from VCDS. The FanCtl_r_ClgDemAC_mp was 100% regardless of AC being on or off. AirC_p_CInt (the AC refrigerant pressure), was 65534 which is effectively maximum, ie implausible. This correlated with the 00256 - A/C Pressure/Temperature Sensor (G395) fault I had. All pointed to a duff sensor. Sensor replaced, all OK now.
  7. Re: 2.0 170 S-line Fan running all the time
    #17
    Jan 2014
    Southampton
    Thats great, Thank you. I got a scan and indeed came up with a fault on the G395 sensor with the 00256 fault code... Although it says sporadic so will check the connector first as it looks a pain to change..
  8. Re: 2.0 170 S-line Fan running all the time
    #18
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Hi everyone! I just notice tonight that my cooling fun is running constantly as soon as I turn on engine and stops when I turn off engine! A6 2.0 tdi March 2011 model 2010) 170 bhp. Does somebody knows what can cause this problem and if I can drive to work about 25 miles? Is any recals for it?
    Thank you for any suggestions!!!
  9. Re: 2.0 170 S-line Fan running all the time
    #19
    Mar 2017
    Rocheste UK
    Sambor11, you really could do with getting a scan for any codes. If you can get VCDS look for the labels in the screenshot I posted, that's the real clincher.
    It's more than likely the AC pressure sensor, the fact that the dealer had 30 in stock is an indication of how common the problem is, but no recalls I'm aware of.
    I drove for a good few months with the problem on mine before I fixed it, no ill effects.
    I forget the exact price, but parts ( sensor and seal) were about £60. It's easy to change, just some sockets and screwdrivers is all you need.
  10. Re: 2.0 170 S-line Fan running all the time
    #20
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by supernoodle View Post
    Thank you for your replay! Can you tell me where is located this sensor?
  1. Replies: 29
    Last Post: 02-10-2013, 10:59 PM
  2. Fan running whole time!!
    By t111bul in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-11-2012, 01:13 PM
  3. Fan stays on most of the time
    By matt925 in forum Golf MK5 - 2004 - 2009
    Last Post: 25-09-2012, 04:45 PM
  4. Please Help a4 s line diesel manual 2010 plate fan staying on !! / a4 s line special addition spec ??
    By garry5510 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2012, 06:36 PM
  5. 1.8 fan on all the time
    By rob160 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2009, 10:30 PM
