Thread: Sharan 1.9 tdi sport 2001 - Vibration
  1. Unhappy Sharan 1.9 tdi sport 2001 - Vibration
    Sep 2007
    Dorset
    Good afternoon all,
    Does any one else have a vibration/wobble from 40 mph up to the max speed limit through the front wheels.
    I first borught the car in Apr 07 and I first noticed a wobble pulling away from the VW dealer. Took it straight back and they said one of the struts had gone - which they replaced, 2nd time picked the car up, noticed vibration/wobble from speeds mententioned above. Took the car back and VW dealer found no faults, wheeles balanced, all under car tight, etc.. VW dealer said it was the car and all Sharan's do this due to the tyre's.
    So, to my question, does any one else have the same issue?
  2. Re: Sharan 1.9 tdi sport 2001 - Vibration
    Sep 2005
    if the dealer says its down to tyres get them to change the tyre see if it persists
    never heard of a wobble of a tyre that is fine
    seen a wobble of a tyre which was damaged and the steel banding in the tyre had failed which put the tyre out of trueness
    this can be any of one thing or a few things combined
    what year is the car?
    how many miles has the car done?
    does it go away after 70mph ?
    what style of wheels is it alloy or steel is the wheels all straight and not buckled as know the new alhambra have problems of the alloy wheel fracturing
    car any signs of accident damage?
    does the problem happen only when gaining speed?
    is the problem still there when you ease off the throttle and getting the carto slow down through the gearbox?
    does it go away if you dip the clutch ?
    does it get worse under harsh braking?
    are your front tyres wearing evenly?
    is the steering responsive ( likes if your turn the steering wheel very little does the front wheels move at the same amount)?
    could be down to worn suspension bushes or steering rack/track rod ends but usually would get some type of brake judder under severe braking
    if goes away when you ease of the throttle could be the clutch at fault/worn inner or out CV joints
    or worn internals in the gearbox
    if tyres are wearing unevenly have you had the tracking checked recently
    failing all this woulg go to a local respectable garage to see if they can pinpoint it and if still not satisfied get a second opinion
    hth
  3. Re: Sharan 1.9 tdi sport 2001 - Vibration
    Feb 2010
    larne
    hi chalkmyster, ive a 2003 tdi alhambra with the same problem i thought it was the dog leg or the engine mount at the bottom of the engine and replaced it, although this did help abit it still didnt solve the problem. after talking to local folk the same answer was given that its most likely the dual mass flywheel it can cause this problem, only remedy is to replace the flywheel and clutch kit. mine hasnt been replaced yet but its due with 100,000 miles on the clock...ive also learned that some companys remanufacture the dual mass flywheel by welding them together and doing a rebalance this seems to be the answer to fixing the troublesome dual mass issue...i'll post comments as soon as my clutch has been replaced as to weather this genuinley resolved the wobble issue...
  4. Re: Sharan 1.9 tdi sport 2001 - Vibration
    Sep 2007
    Dorset
    Thanks for the reply.
    I have now moved on to larger things....VW T4
  1. Induction Kit for my 2001 1.6 a3 sport
    By LB2007 in forum Archive posts
    Last Post: 04-08-2007, 10:07 AM
  2. 2001 1.6 A3 Sport Induction Kit
    By LB2007 in forum Audi A3 - Archive Topics
    Last Post: 28-07-2007, 06:26 PM
  3. 2001 A3 1.6 sport electrical problem
    By Adam159 in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 09:14 PM
  4. Vibration in Sharan 40 - 60 MPH
    By Sam Humphries in forum Touran - Sharan - Caravelle
    Last Post: 19-05-2007, 06:29 PM
  5. A6 quattro sport-2001
    By schuey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-09-2006, 06:25 PM
