Thread: Engine/radiator cooling fan "run on "
  1. Engine/radiator cooling fan "run on "
    Dec 2014
    sedgefield
    A1 1.6 tdi now at 12000 miles. I have noticed at the end of some journeys that the fan continues to run when the engine is switched off. The last couple of times the engine temp was normal before switch off, the journey had been about 20 to 30 mins long and the speed mostly at about 50 mph with indicated outside temperature of 9 - 10 degrees.
    I am used to fans coming on when sat in traffic or going slowly on hot days when in heavy traffic, hard hill climing or otherwise out of water" and usually indicated by the engine temperature guage being above its "normal" level.
    Any others like this?
  2. Re: Engine/radiator cooling fan "run on "
    46 Post(s)
    Normal. You've interuppted a DPF regen.
    make sure you're taking it on a proper good run once every 10 days to let the DPF regenerate properly.
  3. Re: Engine/radiator cooling fan "run on "
    Dec 2014
    sedgefield
    Thanks Chris
    Sounds like, to satisfy one EU requirement to keep emissions down, energy is being used to satisfy the requirement and so economy, fuel costs go up and emmisions go up? Maybe, the engineers are still strugging to keep up with EU directives and at some point in the future we will have a better "way" of control. The petrol engines had a hard time when cats came in for the first few years. May be I should have back tracked to petrol instead of diesel.
  4. Re: Engine/radiator cooling fan "run on "
    Jun 2015
    Amroth, Wales
    Yes, mine starts to run before engine temp reaches normal and then runs for a while when stopped. Definately different to my old A3. Have tried changing both temperature sensors but made no difference so still scratching my head. Ran it for a bit of a run at over 2000rpm too and that made no difference. Still scratching my head.
    Pete
  5. Re: Engine/radiator cooling fan "run on "
    1837 Post(s)
    Quote Originally Posted by hitrac View Post
    Thanks Chris
    yep, it’s all bull **** and box ticking to keep the enviro lobby quiet. Whilst they have all been screaming about Co2, something else has crept up and bitten us on the **** and the result will be war between Russo/China and the West which will do a lot for the environment... actually maybe it will, erasing half the planets population might be a good thing.
  1. Replies: 12
    Last Post: 19-01-2011, 12:40 AM
  2. Clay "stuff" run out. What to replace with?
    By mk4gtiturbo in forum General Detailing/Cleaning Questions
    Last Post: 26-08-2009, 09:31 AM
  3. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  4. Question Cooling fan run time
    By A3sport2004 in forum Audi A3 - Archive Topics
    Last Post: 17-09-2008, 03:08 AM
  5. Passat W8 cooling Fan continues to run
    By junemaddog07 in forum Archive posts
    Last Post: 29-10-2007, 07:10 PM
