Thread: water in tailgate/boot, estate. not washer related
  1. water in tailgate/boot, estate. not washer related
    Nov 2014
    somerset
    Hello
    I have had a look for posts relating to water into boot/tailgate, everything points to the wiper/washer feed.
    it is an estate car and has water in the void between outer and inner metal work.
    I have checked the washer feed pipe and cannot find any leaks, also tired watering down the boot to check the light seals and screen seal.
    The only thing i havent been able to check is the high level brake light unit, anyone know how to remove this?
    The water is internal to the tail gate and when you open it drips from behind the boot card.
  2. Re: water in tailgate/boot, estate. not washer related
    Jul 2013
    76 Post(s)
    Try looking at the wiring grommet as this could ill fitted.
    Dan
    2009/2010 2.0 TDIe SE
    1 1 0
  3. Re: water in tailgate/boot, estate. not washer related
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Wiper motor? Water travels through motor to centre of spindle.
    Alan.
    VW T6 150 DSG Camper £££
    1 1 0
  4. Re: water in tailgate/boot, estate. not washer related
    Aug 2013
    Embra
    I had a rusty tailgate replaced by Audi. New one filled with water...
  1. does a passat estate tailgate - fit in the boot of a passat estate!
    By paulos130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-02-2014, 10:34 PM
  2. Water running into boot when opening tailgate
    By Bah-humbug in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-01-2014, 12:13 PM
  3. B6 Estate - Replacing off side tailgate wiring boot/gaiter
    By Bagpuss69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-11-2013, 05:52 PM
  4. Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    By SiliconS in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2011, 09:28 PM
  5. Question Removing Avant boot door liner - washer water not coming out of washer!
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-03-2011, 11:22 AM
