Thread: Reverse gear unlocking/opening boot...
  1. Reverse gear unlocking/opening boot...
    Sep 2008
    Swansea
    Got a 51 plate Sharan. The boot has never unlocked or been able to be opened just with the handle in the time I have owned it.
    have always had to open it with the key in the boot lock (ie central locking from drivers door won't unlock it).
    Selling the car now and Sod's law each and every time I put car in reverse I can hear the lock go and the boot actually opens slightly.
    Whats causing this? Must be a short of some sort but is there a fuse I can remove?
    2003 Audi A4 SE 1.9tdi 130
  2. Re: Reverse gear unlocking/opening boot...
    May 2007
    17 Post(s)
    My guess would be that the wiring loom between the body and the tailgate is damaged. Near the tailgate hinges you'll see rubber concertina tubing. If you pop the tubing off at the tailgate end and fold it back to expose the loom you might find some of the insulation has broken exposing bare wires. That would seem the most likely cause of your problem.
    Jim.
  3. Re: Reverse gear unlocking/opening boot...
    Sep 2008
    Swansea
    Thanks for that. Pulled it off and there seemed to be a number of damaged wires as per your pic with such s tight area to try and insulate or know if they need repairing. However just be taking apart rubber it's cured it and have checked all lights still working...
  1. Boot not unlocking
    By buster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2010, 11:33 AM
  2. Difficult to select first gear and reverse. Car shudders in reverse
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 11-04-2010, 06:46 PM
  3. Please Help Problem opening boot after unlocking with remote: video
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-05-2009, 10:53 PM
  4. Please Help boot unlocking itself
    By roadrunner in forum Audi A3 - Archive Topics
    Last Post: 28-03-2009, 07:03 PM
  5. Unlocking boot
    By frankieboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 07:27 PM
