Thread: water leak fixed
  1. water leak fixed
    Sep 2007
    stone,staffordshire
    just in case you wandered, the core plug behind the cam pulley had rotted and was spewing water like a baddun. £1.04+vat for new plug from main *******.
  2. Re: water leak fixed
    Aug 2007
    good job, what was involved to replace the core plug?
    My Car: 1997(R) A4(B5) 1.9(AHU) TDI SE 66kw(90HP) Auto(DMV)
    Quote by RAM Circa 2003 " Why would I want a VAG-COM and WT* is it anyway??"
  3. Re: water leak fixed
    Sep 2007
    stone,staffordshire
    the core plug is behind the cam pulley on the cylinder head so basicly you go on as if you are doing a cambelt change, remove the cam pulley and the t belt cover metal backing and there it is. remove old plug (prise out with screwdriver) clean hole, apply a little sealant for luck and drive new plug in with socket. refill engine with coolant ,check for leaks and rebuild.
    it was a mixed blessing really cos my belts were f*****!!
  1. Water Leak
    By mashilo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-09-2007, 07:58 AM
  2. water leak !
    By hitachi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 08:57 PM
  3. water leak
    By johnmccoubrey@t in forum Alhambra
    Last Post: 23-06-2007, 10:45 PM
  4. Water Leak
    By silentwitness in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 11:05 PM
  5. Water leak
    By toledotourer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-10-2006, 04:13 PM
