Thread: 2009 2.0tdi engine management light
Results 1 to 10 of 10
  1. 2009 2.0tdi engine management light
    Nov 2011
    Muckamore, Antrim
    My sis in law needs help.
    The engine management light has come on and it's gone into limp mode. The vw garage say that it's a problem with the fuel rail and that they would try a new pump ( but they were not 100% convinced that this was the problem) and see if that was the problem.
    So far they've charged £66 and now £300 for their time plus parts.
    Has anyone else had similar problems?
    If this is not the problem sorted does she have any come back with them for fitting a part that in hindsight wasn't needed?
  2. Re: 2009 2.0tdi engine management light
    46 Post(s)
    What was the fault code?
  3. Re: 2009 2.0tdi engine management light
    Nov 2011
    Muckamore, Antrim
    Not 100% sure. Restricted fuel supply.
  4. Re: 2009 2.0tdi engine management light
    Pembrokeshire
    22 Post(s)
    as chris says, we would need to know the fault code to comment. sometimes a fault can be tricky to trace. the computer isn't always as helpful as people think it is. so no, you can't really expect a garage not to charge for a job that doesn't cure a fault, unless you can prove beyond all doubt that they were negligent. sometimes a part can be faulty but not actually causing the problem, sometimes 2 parts can be faulty, replace the first and the fault is still there and only cured when the second is replaced. its is very difficult telling customers this at times though. i had one once with landrover td5, kept stalling. it had multiple problems, knackered battery, duff injector, leaking injector seals , duff fuel pump, duff injector harness, fuel pressure regulator leaking and also plumbed in wrong, blocked fuel filter and blocked air bleed valve. i had to replace bits one at a time and each made an improvement, but only replacing the lot made it start and run as it should. his bill was immense, injectors are 500 each. he was happy though , in the end.
  5. Re: 2009 2.0tdi engine management light
    Nov 2011
    Muckamore, Antrim
    I get your point but the garage told her that they didn't have a clue as to what the fault was but that they had seen something similar on a polo. On the polo they had changed the pump and that fixed it so that's what they would try again. Only difference is that with the polo the pump had a strange smell to it when they took it out whereas her pump smelt normal. Wouldn't that in itself suggest it might not be the same issue?
  6. Re: 2009 2.0tdi engine management light
    May 2007
    17 Post(s)
    She'd have no come back if the pump doesn't cure the fault because they are telling her up front that they don't have a clue. I'm sure they didn't actually come out and say that, but if that's the image they're putting across then I'd be taking the car else where. See if you can find a diesel specialist in your area. They should have the knowledge and equipment to diagnose the problem properly rather than taking stab in the dark guesses.
    Jim.
  7. Re: 2009 2.0tdi engine management light
    Pembrokeshire
    22 Post(s)
    yes, quite straightforwards to test fuel pressure really. in this case i would be inclined to agree with flash and get a second opinion.
  8. Re: 2009 2.0tdi engine management light
    Nov 2011
    Muckamore, Antrim
    Thanks for the replies. No that is word for word what they said. Kinda worrying.
  9. Re: 2009 2.0tdi engine management light
    May 2007
    17 Post(s)
    Quote Originally Posted by RobGriff View Post
    Well, I suppose they should get credit for being upfront and honest in that case.
  10. Re: 2009 2.0tdi engine management light
    Jul 2007
    glasgow
    35 Post(s)
    I did a service on a car the other day, Dealer Stamped and Full Service History on a 2009 car .............................. The diesel filter had not been changed since 2009 as it was stamped on Filter
    So sometimes you have to go back to basics and change your filter first ............air filter as well
    Then pressure test
  1. Replies: 1
    Last Post: 15-09-2014, 05:19 PM
  2. 2.0tdi 170 intermittent glow plug light and Engine management light.
    By nigedvd in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 19-06-2014, 10:14 AM
  3. Please Help 2002 Audi A4 1.8t Oil warning light after 5 mins of driving then engine management light comes on
    By ScottyDoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2013, 01:02 PM
  4. engine management light on - A3 2009 TDI 170HP
    By pform in forum 2.0TDi - Engine
    Last Post: 18-07-2010, 09:19 PM
  5. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
