Thread: Facelift tail lights available
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 81
  1. Re: Facelift tail lights available
    #71
    Feb 2013
    Gloucester
    57 Post(s)
    Yes I think so.
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  2. Re: Facelift tail lights available
    #72
    Jan 2015
    Heanor
    Looks right to me
    Quote Originally Posted by buddyboy View Post
    Sorry for bumping an old thread, but are these the modules for the dynamic-like blinking for pre-facelift lights?
    Modul for Semi Dynamic Turning Signal - Audi A7 4G-
  3. Re: Facelift tail lights available
    #73
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    Quote Originally Posted by M1tchy View Post
    Well I managed to get them fitted today and they look great. Here is a "how to guide" and a short video.
    Firstly you need to open the boot and on the inside of the light you will see a bit of black plastic. pull it from the rear of the car and rotate it towards the boot and it will come off.
    Then you will see two Hex bolts, undo them and then pull the light from the inside of the car towards the outside. Then disconnect the cable.
    You will then have a connector like this.
    You need to take it apart. To do this push the small pin shown above and then the connector will just drop out of the bottom.
    You will then have a connector like this...
    You then need to remove the pins and place them in the adapter provided in the kit. To do this just push the metal retainer shown below and pull the pin out.
    You will then have a pin that looks like this...
    To save getting them in the wrong order I placed them straight into the adapter as I removed them. Pin 1 goes into pin 1 in the adapter. 2 to 2 etc etc.
    I was working on installing these this evening and unfortunately i damaged one of the pins, Pin two snapped in half as i was taking it out
    Any idea if you can buy these metal pin connectors anywhere? I need to fix the one on the original wiring to get the module working properly now
  4. Re: Facelift tail lights available
    #74
    Feb 2013
    Gloucester
    57 Post(s)
    Not good
    I've just found some on eBay. Searched for "Audi connector pins". They only came with the connectors too but I'm sure the pins alone are available.
  5. Re: Facelift tail lights available
    #75
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I know, my bloody fat sausage fingers have no finesse for little jobs like this! I sent Ferdi an email asking him if he may have some info on where i could get these pins to repair. failing that ill just have to connect the wire directly to the matching pin on the module wiring loom
  6. Re: Facelift tail lights available
    #76
    Feb 2013
    Gloucester
    57 Post(s)
    At chance you can solder it together as a temporary fix?
    If I remember rightly, I removed the cable tie next to your thumb and peeled back some on the tape to give a bit more room to move the cables and pins
  7. Re: Facelift tail lights available
    #77
    Feb 2013
    Gloucester
    57 Post(s)
    Cancel that, just found these which is what I think you need....
    10 x Male & Female Superseal 1.5 Series Terminals For Wire Size 0.5mmsq-1.5mmsq
  8. Re: Facelift tail lights available
    #78
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I was thinking of getting a bullet connector or similar for the time being, Ill see what i can pick up locally tomorrow.
    Thanks for the link, ill order some up to see if they will do the job and fit the connector
  9. Re: Facelift tail lights available
    #79
    Feb 2014
    norway
  10. Re: Facelift tail lights available
    #80
    Feb 2013
    Gloucester
    57 Post(s)
    Quote Originally Posted by soft View Post
    They look real. Only possible problem is there are only 2 versions of these lights, US and rest of the world. The US ones have a red sweeping indicator while ROW have Amber. Will be worth confirming if you’re looking to buy a set.
    Sent from my iPhone using Tapatalk Pro
  1. A6 Tail Lights
    By Bill-l in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-11-2010, 05:41 PM
  2. Question LED Tail lights?
    By barreoty in forum Bora - 1998 - 2005
    Last Post: 15-03-2010, 01:11 PM
  3. LEDs Tail Lights for A4 B7?
    By poyorudo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-02-2010, 10:21 PM
  4. tail lights
    By BVF in forum Golf MK4 - 1999 - 2004
    Last Post: 20-01-2009, 10:17 PM
  5. A4 B7 Led Tail Lights?
    Last Post: 31-01-2008, 02:44 AM
