Thread: 17571 code
Results 1 to 10 of 12
  1. 17571 code
    Nov 2008
    just read a kids codes at work, he's having trouble starting his golf, 1.9 tdi 130 bhp it's throw up this code
    anyone know the part number required to fix this ?
    here's a clip of the scan
    Wednesday,29,October,2014,15:46:26:65217
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Mileage: 189040km/117464miles
    Address 01: Engine Labels: 038-906-012-AGR.lbl
    Part No: 038 906 012 M
    Component: 1,9l R4 EDC 0000SG 2813
    Coding: 00002
    Shop #: WSC 00028
    VCID: 1A31CA28866178CE7A7-4A3A
    1 Fault Found:
    17571 - Fuel Temp Sensor (G81)
    P1163 - 35-00 - Open or Short to Plus
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
    Part No: 1C0 907 379 C
    Component: ABS FRONT MK60 0103
    Coding: 0001025
    Shop #: WSC 00028 000 00000
    VCID: 2A511AE88601E84EEA7-5072
    No fault code found.
    Address 08: Auto HVAC Labels:
    Part No: 3B2 907 044 C
    VCID: 2241F2C8AE31300EA27-515A
    2008 Audi A6 2.0 tdi s line avant. BRE engine. 19" le mans alloys, bluetooth, sat nav,full leather
  2. Re: 17571 code
    40 Post(s)
    Start by changing/checking the fuel temperature sensor and go from there.
    17571/P1163/004451 - Ross-Tech Wiki
    17571/P1163/004451 - Fuel Temp Sensor (G81): Open or Short to Plus
    Possible Symptoms
    Fuel consumption higher then normal
    Starting the engine is not as easy as normal
    Emission Levels not met
    Possible Causes
    Wiring/Connectors from/to Fuel Temp Sensor (G81) faulty
    Possible Solutions
    Check/Repair Wiring/Connectors from/to Fuel Temp Sensor (G81)
    Check/Repair Fuel Temp Sensor (G81)
  3. Re: 17571 code
    May 2007
    7 Post(s)
    Personally, if I had VCDS, I'd check the wiring first:
    Read the fuel temp in measured values (block 07, I think). It'll probably be at -20'C or something since it's an open circuit fault code.
    A quick and dirty wiring test would be to simply short the two pins of the fuel temp sensor connector together (harness side). If the wiring is OK the measured value will change to something higher than the ambient temperature.
    You'll also have a new DTC in memory if the wiring is OK. Your original open/short to B+ will now be intermittent and you'll have a G81 short to ground.
    If the wiring checks out OK, now you can replace the sensor with a degree of confidence that it'll cure the problem.
    Jim.
  4. Re: 17571 code
    Aug 2011
    Meath
    These sensors are cheap, easy to change and they do fail
  5. Re: 17571 code
    May 2007
    7 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    Maybe, but why replace something that isn't broken? Surely if the sensor is easy to replace, it must be even easier to do the wiring check and know for sure why your replacing it.
    And wouldn't you feel a little better about your investment in VCDS when you get to use it as something more than a code reader?
    Jim.
    0 2 0
  6. Re: 17571 code
    Aug 2011
    Meath
    Quote Originally Posted by Flash2 View Post
    Jim.
    You can also check the pressure in a bald tyre even though experience tells you it's not fit for purpose
  7. Re: 17571 code
    May 2007
    7 Post(s)
    Sorry, but I don't get your point.
  8. Re: 17571 code
    Sep 2007
    I have this fault code - please could you tell me where is it located on a Polo 1.9 TDI (100PS) (2005). My local europarts does not seem to have the item, is it direct from VW? thanks
  9. Re: 17571 code
    Dec 2010
    Worcs, UK
    It will be on a flange near front of engine or side of cylinder head.
    Might be able to give you a part number.
    Which engine code do you have?
    Where are you from?
  10. Re: 17571 code
    Sep 2007
    Hiya thanks, I 'think' this is the sensor, front left of engine. You can see the Oil filter assembly to the left. It does fit to a fuel pipe. If you have a part number that would be great.
    Engine code is ATD642798, I am in Salisbury.
    Kind Regards Richard
  1. Replies: 2
    Last Post: 22-10-2014, 03:44 PM
  2. Audi TT Chorus stereo code not with car, help needed getting code
    By acordery in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-08-2013, 02:38 AM
  3. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
