Thread: GEARSHIFT CABLES ADJUSTMENT/Slack
  1. GEARSHIFT CABLES ADJUSTMENT/Slack
    Apr 2017
    Stourport UK
    Hi All
    Can anyone give me advice as to the correct way to take up the slack in the gearshift cables on my 2003 VW Golf 1.9 GT TDi 130.
    I have looked on YouTube and understand what to do but my gearbox doesn't have the L shaped pin/lever or plunger you have to push in on the gearbox to lock the arm mechanism whilst taking up any slack in the cables.
    On top of the gearbox there is a plastic plug/cover over what looks like a hole but I am unsure and reluctant to insert a pin (5mm) to lock the mechanism.
    There isn't a lot of slack movement at the gearstick but just wanted to see if it made a difference and make life easier for my wife when she drives it.
    CHEERS
    MARTIN
  2. Re: GEARSHIFT CABLES ADJUSTMENT/Slack
    Jan 2009
    Birmingham
    35 Post(s)
    5 or 6 speed?
  3. Re: GEARSHIFT CABLES ADJUSTMENT/Slack
    Jan 2009
    Birmingham
    35 Post(s)
    IS THIS ANY HELP SHOWS FOR TWO METHODS FOR DIFFERENT GEARBOX DATES
    Adjusting selector mechanism, gearbox with retaining pin (through gearbox date 18 05 3)
    The selector shaft -A- is secured with a retaining pin -arrow-.
    Special tools and workshop equipment required
    t Locking pin -T10027-
    Note
    t The following points are essential to ensure correct adjustment of selector mechanism:
    t Moving parts of selector mechanism and elements transferring force must be in proper condition.
    t Selector mechanism must move freely.
    t Gearbox, clutch and clutch mechanism must also be in proper condition.
    l Gearbox must be in neutral.
    Pull locking mechanisms on gate selector cable and gear selector cable forward to stop -direction of arrow 1- and then turn to left to lock -direction of arrow 2-.
    Secure selector shaft as follows:
    Press selector shaft down -direction of arrow 1-.
    While pressing selector shaft down, push locking pin -A- into gearbox (-direction of arrow-) until it engages.
    This locks the selector shaft; it cannot be moved any more.
    Carefully lever cover off centre console -arrows-.
    Now secure gear lever as follows:
    Move gear lever in neutral leftwards into gate for 1st and 2nd gears.
    Guide locking pin -T10027- through hole -A- into hole -B-.
    Now turn locking mechanism on gear selector cable and gate selector cable clockwise to stop (-direction of arrow-).
    Spring presses locking mechanism into original position.
    Now pull locking pin -A- back to original position (-direction of arrow-).
    Pull locking pin -T10027- out of holes -A- and -B-.
    Clip gaiter into frame.
  4. Re: GEARSHIFT CABLES ADJUSTMENT/Slack
    Jan 2009
    Birmingham
    35 Post(s)
    Adjusting selector mechanism, gearbox with angled rod from gearbox date 19 05 3)
    The selector shaft -A- is secured with an angled rod -arrow-.
    Note
    While pressing down selector shaft, turn angled rod -A- in -direction of arrow 3- upwards and at the same time press it in -direction of arrow 2- until it engages in selector shaft.
    Select neutral using gear lever.
    Now turn locking mechanisms on gear selector cable and gate selector cable clockwise to stop -direction of arrow 1-.
    The spring presses the locking mechanism into original position -direction of arrow 2-.
    Now turn angled rod -A- back to original position -direction of arrow 2-.
    During this procedure, locking pin -A- must be pressed out of gearbox in -direction of arrow 1-.
    It must now be possible to move selector shaft in -direction of arrow-.
    Press gaiter into cover.
  5. Re: GEARSHIFT CABLES ADJUSTMENT/Slack
    Jan 2009
    Birmingham
    35 Post(s)
    Functional check
    l With gearbox in neutral, gear lever must rest in gate for 3rd and 4th gear.
    Operate clutch.
    Select all gears several times. Pay particular attention to operation of reverse gear lock.
    If it continues to be difficult to engage a gear after repeated attempts, repeat adjustment procedure of selector mechanism
  6. Re: GEARSHIFT CABLES ADJUSTMENT/Slack
    Apr 2017
    Stourport UK
    Hi arman123 Top gear
    Thanks for the quick reply and comprehensive instruction sheets.
    This is the methods viewed on You Tube but I was obviously not looking in the correct place for the locking plunger.
    Will give it another go tomorrow after work.
    Put my glasses on this time.
    Martin
  1. Audi S6 Gearshift
    By as400 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-12-2015, 11:19 PM
  2. D4 gearshift paddles
    By velour in forum A8 - S8 - V8
    Last Post: 20-07-2014, 08:56 PM
  3. Gearshift Indicator
    By chiefwiggumpi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2009, 10:14 AM
  4. Please Help audi a4 slack in gear lever - help
    By scotchydoodle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2009, 11:22 PM
  5. A4 1.8T Quatro manual gearshift
    By bluesky in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2008, 07:16 PM
