Thread: Crank pulley failure
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
  1. Crank pulley failure
    May 2014
    Darlington
    78 Post(s)
    So was just pulling off the drive this evening head a noise and then the dash started lighting up, battery light, ESP light etc. Pulled back into the drive and had no power steering which made it almost impossible to steer as it was heavy as hell.
    When opening the bonnet i found the serpentine belt rubbing against the cooling fan and the crank pulley at the bottom of the engine bay!
    I managed to get a hook around the ripped off pulley and fish it out.
    It's difficult to tell on the photo but it's the rubber damper that has failed
    Looks like the it's been on it's way out for some time as you can see the rust has seeped into the rubber
    Looks like I'm going to have a fun weekend stripping the front of the car down replacing the pulley.
  2. Re: Crank pulley failure
    Pembrokeshire
    22 Post(s)
    see plenty of these on various vehicles doing this. last one was a mitsubishi l200.
  3. Re: Crank pulley failure
    Aug 2011
    Meath
    You'll do that in 3 hours
    1 1 0
  4. Re: Crank pulley failure
    May 2014
    Darlington
    78 Post(s)
    It's an easy enough job depending on the condition of the bolts holding what left of the crank pulley in place. Have to say it's the first time I've had one fail.
  5. Re: Crank pulley failure
    Aug 2011
    Meath
    Quote Originally Posted by B5NUT View Post
    Replace the crank pulley bolts when you change it, they're soft and at least 1 will require a 12 point socket hammered on to it IME
    1 3 0
  6. Re: Crank pulley failure
    Sep 2011
    Lurking over a keyboard ...
    Known issue on early V6 TDi, seen now several threads/posts whilst haunting forums.
    If you have access to TPI / TSB data B5NUT the crank pulley vibration damper was updated to new part as vulcanisation fails.
    There is also a washer which must be used as per TPI / TSB that early V6 TDi didn't have.
    PM/email I will send you info.
    2 1 0
  7. Re: Crank pulley failure
    May 2014
    Darlington
    78 Post(s)
    To be fair it's done almost 200K miles, if I had know it was a common failure I would have replaced it when I had the front-end stripped down. I'll be getting new bolst, you do tend to find that all the bolts, clips and nuts at the front of the engine get destroyed, I don't mind replacing them and it's easier when you come to do the job but even with TPS prices it can add a fair amount to the job
    Gupsterg I take it your talking about the compensation washer part number WHT 000 950 A? Looking at etka my part number pulley 059 105 251 AD was dropped 01/08/2014 I've been able to source a new genuine pulley but the older part number for just over 100 and if that last another 200K mile it will just about see the life of car out. The new version is around 240 so it's a fair saving.
    I'll PM you my email address, I made mistake updating elsawin so need to start from scratch!
    2 0 0
  8. Re: Crank pulley failure
    Nov 2012
    Somerset UK
    B5, sorry to hear Something I'll have to look at as living half a mile from salt water I've found I'm more susceptible to rust than most.
    Good luck in getting it fixed.
  9. Re: Crank pulley failure
    May 2014
    Darlington
    78 Post(s)
    There was no warning as well, and there is little room between the slam panel & the engine so it's not easy to check the condition. The problem you have when it does go it takes out the water pump, power steering, alternator and aircon so the car is undriveable with the water pump out of action, just glad it failed at home and not miles away from home.
  10. Re: Crank pulley failure
    42 Post(s)
    978 Post(s)
    On certain 4F A6 V6 TDI there is a recall over that.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  1. Crank / Alternator belt pulley...
    By JeffTheGeek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-06-2017, 10:32 AM
  2. Crank shaft pulley wobbling
    By vw_golf_nutter in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2012, 05:54 PM
  3. Crank shaft pulley
    By morgans in forum Alhambra
    Last Post: 24-04-2010, 10:22 PM
  4. How do I get the crank shaft pulley off?
    By Oliverpaton in forum Golf MK2 - 1984 - 1992
    Last Post: 21-03-2009, 08:59 PM
  5. crank pulley
    By dangerousdog in forum The Commercial Range
    Last Post: 02-11-2008, 04:10 AM
