Thread: MMI not working, black screen and controls
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. Re: MMI not working, black screen and controls
    #21
    Sep 2013
    Measham, UK
    £2.5k?! Bloody hell! Really? :-(
    Sent from my GT-I9505 using Tapatalk
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  2. Re: MMI not working, black screen and controls
    #22
    May 2014
    Darlington
    78 Post(s)
    Another thing I would try is to remove the fuse for the 5F module and leaving it powered down for a few minutes, as it could just be the firmware is in a faulty state.
    Another option is to check all the connections behind the glove box, you only need an 8mm socket to remove the glove box.
    Also check all the connections are secure, it should look something like this behind there but your wiring will look neater and better length, mine looks like that as I retrofited MMI 3G.
  3. Re: MMI not working, black screen and controls
    #23
    Sep 2013
    Measham, UK
    Hmmm that's interesting. I fitted my own ami and was all ok but the glove box was rattling so I took it out about 2 weeks ago. Might give that a try first. I hope it's as simple as that!
  4. Re: MMI not working, black screen and controls
    #24
    May 2014
    Darlington
    78 Post(s)
    Quote Originally Posted by Owendavies View Post
    Yes the 5F unit replaces a lot of modules, Navigation, BT, AMI and SDS so Audi charge ££££. I've purchased a few 5F HDD units off ebay and the most I have paid is £300, and that was for the HDD & SIM version
  5. Re: MMI not working, black screen and controls
    #25
    Sep 2013
    Measham, UK
    Ok I'll try removing the glove box again and making sure the connections are secure. It is very on and off (literally) so it could just be a loose cable? Damn, I hope it's just that! :-(
  6. Re: MMI not working, black screen and controls
    #26
    May 2014
    Darlington
    78 Post(s)
    You may find the quadlock connector is not secure and causing the fault, may explain why it's not showing up in the optical bus list.
  7. Re: MMI not working, black screen and controls
    #27
    Sep 2013
    Measham, UK
    Well, I dropped the glovebox out this morning and had a look at the wires. Removed the quadlock and put back in, no change
    When I put the key in the ignition (not turned) the 5f unit (the nav/sd card unit?) whirs on and off, the fan spin up and down half a dozen times then cuts out. Not sure if this is normal behaviour?
    Anyway, still getting nothing when the key goes in and very temperamental when it actually loads MMI, if at all.
    Also, did a scan with te unit 'working' and this is what I got:
    Saturday,25,October,2014,16:25:57:37271
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0
    Data version: 20140822
    Gateway Installation List: 4F0 907 468 M
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    And when I do the optical bus diag this happens:
    Doesn't look good for the 5f unit then? M
    Maybe I'll take a look at Ebay!
    Owen.
  8. Re: MMI not working, black screen and controls
    #28
    May 2014
    Darlington
    78 Post(s)
    No, the fan should not do that, it does sound like the unit is faulty.
    Look for a unit starting with 4E0 don't bother if say's A8, Q7 etc as the firmware on the unit will work on the A6, just need to change the car type in the hidden menu.
    You could also look at a 4H0 module which is MMI 3G+ but it's unknown what will work correctly, and you would need to flash the radio & CD-Change with the 3G+ firmware and i'm not sure if they could be flashed back to 3G. (I'm about to fit MMI 3G + into my a6 and see what works, and what is broken.... I should know this in the net few weeks.)
    I would look at either a 666 unit or 670 that will give you the HDD & SIM option
    Part number ends in 666 = HDD
    Part number ends in 670 = HDD + SIM
    One like this AUDI A6/A8 MMI 3G MULTIMEDIA CD/SD PLAYER 4E0035670/4E0 035 670 | eBay
    Ignore anything with 8V0 which is A3 and I don't believe the firmware on the unit will work in an A6. An A4 unit may would but you would need to change the faceplate.
  9. Re: MMI not working, black screen and controls
    #29
    Sep 2013
    Measham, UK
    Thanks for the info. If I went for the hdd version, how would that tie in with my current system? I upgraded to the 2014 maps, could I get these on the new unit?
    Would love to go 3G+ but not confident enough to lol had no problem ripping my Mondeo apart but this is a bit different for me.
    Sent from my K00C using Tapatalk
  10. Re: MMI not working, black screen and controls
    #30
    May 2014
    Darlington
    78 Post(s)
    Yes very easy to update with the latest 2014 firmware and maps + the HDD maps give far mode detail and actual 3D views of citys. PM for firmware & maps details.
    The HDD unit is a direct replacement for your faulty one, and all your existing hardware will just work. The only module you will need to code is the new 5F module to set the options you have fitted to you car.
  1. Have I ruined my MMI screen?
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2013, 04:49 PM
  2. Door controls not working
    By BIGECK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-10-2010, 10:08 PM
  3. help steeringwheel controls and horn not working
    By chrisb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-06-2009, 08:38 PM
  4. CD Changer - MMI Controls
    By bluestar_ale in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-07-2008, 02:43 PM
  5. Satnav screen / moving heating controls
    By Cosmosblue in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2007, 09:45 AM
