Thread: MMI not working, black screen and controls
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
  1. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    Quote Originally Posted by B5NUT View Post
    Run the optical bus Diagnostic (System need to be in a fault state when you run this)
    Questions.
    Do you have bose
    Did you power down the radio module like I said in my first post.
    Can you post up the gateway installation list.
    Thanks everyone for all the replies, I knew I could rely on you guys
    I don't have Bose.
    I have powered down the radio module, but it's gone down hill to a new level; it's now cutting in and out of all inputs randomly (when it actually works). Is this component protection or just a further issue?
    Gateway installation list:
    Friday,24,October,2014,14:39:20:37271
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0
    Data version: 20140822
    Mileage: 117160km-72799mi Repair Order:
    Control Module Part Number: 4F0 907 468 M
    Component and/or Version: GW-BEM 4CAN-M H06 0035
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway ERROR ERROR
    0E-Media Player 1 ERROR ERROR
    56-Radio ERROR ERROR
    They are the only ones that came up, which was also a bit worrying. Shouldn't the ones that were ok supposed to show too?
    Owen.
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  2. Re: MMI not working, black screen and controls
    May 2014
    Darlington
    78 Post(s)
    Yes you are missing the 5F module (main MMI controller) in that list.
    Can you post your gateway installation list.
  3. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    That's all that came up :/ I tried it a few times as well! I'll take a screen shot if it next time.
    Sent from my GT-I9505 using Tapatalk
  4. Re: MMI not working, black screen and controls
    May 2014
    Darlington
    78 Post(s)
    So If you select Application and then select Gateway Installation List
    You get nothing?
    You should get something like this
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 72 76 77
    VIN: WAUZZXXXXXXXXXXXXX Mileage:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    If yours is blank you need to find the Fuse for the 5F module Audi Multimedia (I think it should be a 15AMP fuse)
  5. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    Ahh sorry, thought you meant the gateway installation list? I posted that above, giving the 3 modules with errors.
    If you want the output from the scan I'll post that...
  6. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    05-Acc/Start Auth. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
  7. Re: MMI not working, black screen and controls
    #17
    Sep 2013
    Measham, UK
    All ok except 19 CAN Gateway (& auto hvac but that always comes up :/)
  8. Re: MMI not working, black screen and controls
    #18
    May 2014
    Darlington
    78 Post(s)
    Can you post up the latest error codes for the can-gateway. Just want to see if the Optical bus error Fault Frequency has increased.
    From the looks of this it does appear that your 5F module is faulty, if you perform another
    Optical Bus Diagnostic does it appear?
  9. Re: MMI not working, black screen and controls
    #19
    Sep 2013
    Measham, UK
    I'll give it a go in the morning, it ******* it down outside at the moment lol
    Thanks for the quick replies by the way. If 5f is faulty, can I replace it or dealer only?
    I've got it booked in to Derby Audi on 3rd November just in case but they're charging me £60 just for diagnostic that I've done myself anyway :-( then obviously repair bill!
  10. Re: MMI not working, black screen and controls
    #20
    May 2014
    Darlington
    78 Post(s)
    Your best of replacing the module, not unless you have a spare £2,500 doing nothing! As that is just the cost of the module you the will need to add at least an hours labour may be more if the replacement module requires firmware updates.
    Also if does turn out that the module is faulty then your best off looking for one on ebay (you can get them for around £300 - £500), and you could also think about getting a hard disk version. The only thing you will need to go for Audi is to remove component protect. All the coding and configuration you can do yourself via VCDS or the hidden menu.
  1. Have I ruined my MMI screen?
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2013, 04:49 PM
  2. Door controls not working
    By BIGECK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-10-2010, 10:08 PM
  3. help steeringwheel controls and horn not working
    By chrisb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-06-2009, 08:38 PM
  4. CD Changer - MMI Controls
    By bluestar_ale in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-07-2008, 02:43 PM
  5. Satnav screen / moving heating controls
    By Cosmosblue in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2007, 09:45 AM
