Thread: Instrument Cluster in MMI menu greyd?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
  1. Re: Instrument Cluster in MMI menu greyd?
    #21
    Sep 2014
    Sweden
    Maybe I need to update MMI version??
    Gupsterg, yes it is set to 5 in hidden menu.. :/
  2. Re: Instrument Cluster in MMI menu greyd?
    #22
    May 2014
    Darlington
    78 Post(s)
    It's not just the MMI that is not working as, he states he cannot switch between the dis options using the stalk. #15 & #16
  3. Re: Instrument Cluster in MMI menu greyd?
    #23
    May 2014
    Darlington
    78 Post(s)
    Quote Originally Posted by tomaslund View Post
    All versions of the MMI 3G software be it the HDD or the DVD version support DIS.
  4. Re: Instrument Cluster in MMI menu greyd?
    #24
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by B5NUT View Post
    Yes I understand, I was just trying to findout what the car menu operation was set to .
    So there is no differing version of steering elec.module so all must support stalk/coding change for DIS?
    There is no differing stalks, we know that in the 2009-11 range the standard A6 (the model below SE) with MMI 3G Radio plus does have stalk with DIS function as there are UK cars with it.
    I've also checked PR codes relating to instrument clusters and all support onboard/check control.
    So Thomas in CAR > CARDEVICELIST > On Board Computer is checked?
  5. Re: Instrument Cluster in MMI menu greyd?
    #25
    May 2014
    Darlington
    78 Post(s)
    If all the coding is correct the only thing I can think of is there is a lowline factory SCSM and if you have to replace this module you get the model listed in etka (complete wild guess) as for some reason neither the MMI or the stork can communicate to the DIS.
    Without a scan of the car I'm now stumped.
  6. Re: Instrument Cluster in MMI menu greyd?
    #26
    Sep 2014
    Sweden
    Gup, on board is not checked! But isn't that for the display of Climate settings, that one I don't have. Basic turner wheels to adjust climate.
    I will try to get a scan as soon as I can, but won't be until the weekend I guess.
  7. Re: Instrument Cluster in MMI menu greyd?
    #27
    Sep 2011
    AFAIK
    carmenuoperation is for selection of menus/how/when displayed
    cardevicelist is what installed
    air condition refers to climate control
    Please check onboard computer and reboot MMI and report back.
  8. Re: Instrument Cluster in MMI menu greyd?
    #28
    Sep 2014
    Sweden
    Gupsterg , couldn't find any on board computer just something called "bord computer" the exact spelling.
    This is weird I will post a scan soon
  9. Re: Instrument Cluster in MMI menu greyd?
    #29
    Sep 2014
    Sweden
    ssis Type: 4F (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 42 46 4F 52 53 55 56 5F 62
    69 72 76
    VIN: WAUZZZ4F19N058275 Mileage: 122100km/75869miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 FH HW: 03L 906 022 FG
    Component: R4 2,0L EDC H01 6418
    Revision: 11H01--- Serial number:
    Coding: 010D002C02072920
    Shop #: WSC 40204 222 97124
    ASAM Dataset: EV_ECM20TDI03L906022FH A01009
    ROD: EV_ECM20TDI03L906019AH.rod
    VCID: 70E5C880AB5DD29E643-8025
    1 Fault Found:
    7140 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F9 910 155 D HW: 01J 927 156 JG
    Component: V30 0AN 2.0l CR RdW 0010
    Revision: --H05--- Serial number: 00000000000468
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 2C5D1CF08FF5F67E18B-8079
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
    Component: ESP8 front H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004476
    VCID: 6DDBD1F4746F3F764F5-8038
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601306652
    Coding: 0000131
    Shop #: WSC 02323 785 00200
    VCID: 254BE9D4EC1FC736C75-8070
    Subsystem 1 - Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 AA
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000033 Serial number: 00000000622815
    Coding: 0000276
    VCID: DBBF0F2C1ADBC1C6211-808E
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0003222
    Shop #: WSC 02335 785 00200
    VCID: 346D049057C5AEBE40B-8061
    Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003CH004EXTQ
    Coding: 30314236303630303031554A304C34463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 306508806BDD929E243-8065
    Crash sensor for side airbag; driver side:
    Serial number: 3574SRB400008B20FABH
    Crash sensor for side airbag; passenger side:
    Serial number: 3584SRB400008B213AC8
    Crash sensor for side airbag; rear driver side:
    Serial number: 35152RB402J7V8VGURKY
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35252RB402L7V8VGMKBD
    Crash sensor for front airbag; driver side:
    Serial number: 3554NRB400004B14907W
    Crash sensor for front airbag; passenger side:
    Serial number: 3564NRB400004B13CEED
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90026090960219
    Coding: 0002042
    VCID: 2757E3DC9613D526F59-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 121595 km
    Time Indication: 0
    Date: 2014.10.17
    Time: 19:35:07
    Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 901 J HW: 4F0 920 901 J
    Component: KOMBIINSTR. H06 0135
    Revision: 00100000 Serial number: ADR05ZY39
    Coding: 0F57110502000408010100
    Shop #: WSC 02391 823 56573
    VCID: 2953E5E44007E356E3D-807C
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 L HW: 4F0 907 468 G
    Component: GW-BEM 5CAN-M H06 0025
    Revision: 4MA90025 Serial number: 2500M093318161
    Coding: 000303
    VCID: 387530A08BAD4ADE6C3-806D
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
    Part No SW: 4F0 857 511 H HW: 4F0 857 511 G
    Component: FLA H04 0003
    Revision: AA001002
    Coding: 02010464747464545425363E
    VCID: 2D5B11F474EFFF760F5-8078
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000100942096
    Coding: 011C06204040410001
    VCID: 46894E58F1592C2EEEF-8013
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01179761440000
    Coding: 0197361
    VCID: 31630D84A8D79B962BD-8064
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000626601
    Coding: 0001104
    VCID: DEB9063809C9D4EE46F-808B
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000100930971
    VCID: 458B4954CC5F2736E75-8010
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 49
    Reset counter: 191
    Mileage: 120850 km
    Time Indication: 0
    Date: 2014.10.10
    Time: 14:31:52
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000131
    Shop #: WSC 02145 785 00200
    VCID: 2143FDC4F8372B16BBD-8074
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F875BBC6E837DE6AD9-806A
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342D0097594984
    Coding: 010003020100000000
    VCID: 1F47FB3C0E431DE68D9-804A
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 646 B HW: 4E0 035 646
    Component: B-B-ER H51 0040
    Revision: -------- Serial number: 348D-097523376
    Coding: 01010001020282CD01000705EF6300000200
    Shop #: WSC 40350 222 91638
    VCID: 234FF7CC222B3906A91-8076
    Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 M
    Component: Bedienteil MM H01 0060
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000100961246
    Coding: 010804204040220001
    VCID: 438F574CC26B1906C91-8016
    Address 69: Trailer (J345) Labels: 4F0-907-383.clb
    Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
    Component: Anhaenger H08 0080
    Revision: 2B002002 Serial number: 00000117584587
    Coding: 0103030000000000
    VCID: 2C5D1CF04FF5F67E18B-8079
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000100951741
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 B HW: 4L0 919 283 B
    Component: Parkhilfe 4-Kan H02 0500
    Revision: 00H02000 Serial number: 12330910003494
    Coding: 0211016
    VCID: 2953E5E48007E356E3D-807C
  10. Re: Instrument Cluster in MMI menu greyd?
    #30
    Sep 2011
    bord computer is onboard computer.
  1. MMI 2g hidden menu
    By Tim B in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-04-2013, 01:12 PM
  2. Accessing MMI Hidden Menu on Facelift B8 with MMI 3G
    By aled_31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-04-2012, 08:34 PM
  3. MMI Hidden Menu
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 22-12-2011, 05:22 PM
  4. Accessing hidden menu on MY2010 3G MMI
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2010, 07:55 PM
  5. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
