Thread: Mysterious fault code
  1. Mysterious fault code
    May 2009
    Saddleworth, Yorkshire
    due to an engine fault (keeps going into limp mode) have had my cars fault codes cleared and following a drive I have got one fault re showing - UOCD2
    i can not find out what this code means, any suggestion welcome
    the car is a 2010 Ibiza 1.6 tdi
    thanks in advance for any help.
    Ian
  2. Re: Mysterious fault code
    46 Post(s)
    Get it to a audi/vw specialist and get it scanned with VCDS to get an accurate diagnosis.
  3. Re: Mysterious fault code
    Sep 2014
    Australia
    Network Communications ("U") codes (controller area network wiring bus and modules)
    The OBD II system monitors all of the emissions-related functions in your vehicle, including the ignition and fuel systems, engine misfires, catalytic converter, evaporative emissions (EVAP) control system and various other emission control systems (EGR, PCV, etc.). Many of these functions are monitored anytime the vehicle is driven (continuous monitors) while others are only monitored when certain operating or driving conditions have been met. The OBD II system may run certain self-tests (such as checking for fuel vapor leaks) periodically.
    If a component or system is not operating normally within acceptable limits or fails a self-test, the OBD II system records one or more "Diagnostic Trouble Codes" (DTCs) that correspond to the fault, and turns on your Check Engine Light to let you know there's a problem.
    If only life were simple with the VW
  4. Re: Mysterious fault code
    May 2009
    Quote Originally Posted by Doc Vernon View Post
    Hi many thanks for your very informative reply, can you suggest anyway of me being able to identify which component might be giving me the fault that I have. Now that I have the fault codes cleared the fault has gone away, at the moment.
    The fault was the glowplug light cam o flashing and the power went down ie no turbo, some times if I turned the engine off and on it cleared the fault for the rest of the day. This only lasted for a week then engine light came on and the fault was permanent. The car has done 48K miles and has lived on t motorway for the 18 months that I have owned it.
    Regards Ian
  5. Re: Mysterious fault code
    Sep 2014
    Australia
    Think you need an OBDII tool to do a diagnostic check of that UOCD2 Code!
    Alternative you can take it to any good Mechanic for that test!
    Would cost about $65 Aussie not sure in GBP.
  6. Re: Mysterious fault code
    May 2009
    Many thanks for advice
  1. Dreaded ESP Fault DIS warning and G201 fault code
    By Daz6546 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2015, 01:53 PM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
