Thread: AMI fitted but issue. Any help please
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    Hi all,
    just fitted the DAB and AMI units to my Allroad. It was running a later software (5150), so the units appeared straight away. The DAB came straight on and is just waiting for me to finish the aerial connections. The AMI module however comes up as selectable, but nothing I plug into it seems to work or charge. It just says "this item my not be connected properly or may not be working correctly. Is there a chance that something still needs to be turned on with VAGCOM. I did update to 5570 as well just to be sure, but discs one and two didn't need to update anything as the bits for the various updates on there all said no update required, latest installed. Only disc therefore was disc three which took it to 5570 which went fine but made no difference to AMI.
    I tried wiring it without any splitters in place of the CD changer, and again, it comes up, but no go. Tried a phone and three types of iPods, but nothing.
    Any advise gladly received.
    Thanks all.
    Allroad 3.0 TDI 2006 with MMI High
    More Muppet than Man
  2. Re: AMI fitted but issue. Any help please
    Sep 2011
    Lurking over a keyboard ...
    What AMI lead are you using? ie P/N or IIRC colour band on lead?
  3. Re: AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    Do you mean the interface lead from AMI to device? In which case it is an iPod lead (older style) which came with it like the one here - For Audi VW AMI MMI Audio Cable Adaptor Interface Lead Connector For iPod iPhone | eBay . It does not have any identifying writing or manufacturers part numbers on it or any colour bands of any sort. The leads in the back are simply a power splitter lead and a splitter optical lead.
    Thanks again.
  4. Re: AMI fitted but issue. Any help please
    46 Post(s)
    fake cable, get a genuine one. They're about £20.
  5. Re: AMI fitted but issue. Any help please
    Apr 2009
    Surrey
    174 Post(s)
    Try powering off and then restarting the iPod whilst it is connected to the AMI
  6. Re: AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    Thanks for the suggestion. Gave it a try, but no go. I think the clue may be in the fact that it doesn't charge either. So it's not just not seeing an iPod, it also is not giving it any feed.
    I've also just ordered a genuine lead, so will see if that makes any difference.
  7. Re: AMI fitted but issue. Any help please
    Sep 2011
    Quote Originally Posted by Muppet_man View Post
    Sorry for delayed reply but the thread had been moved sections and I didn't view updates in inbox .
    Where you got the power/optical cable not matter as long as connected correctly and work.
    Why I ask about colour bands is that IIRC MMI 3G AMI cables have them and I don't think they work with MMI 2G AMI.
    Genuine cable will have P/N sticker and my AMI USB cable also have MITSUMI stamp on metal plug which go to AMI socket.
  8. Re: AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    Hi,thanks for the reply. Just received a new one from an online seller. Audi original lead with a blue collar part number: 4F0 051 510 K - photo included. It has come of the same numbers, but I notice the IC number is different also.Plugged it in, but sadly no charging and when you select the input, it says the same thing "your device may not be connected or operating properly"I will check with Audi in the morning to see if the 510 K is an updated version of 510 Q.Other than that my only things left are the AMI is buggered, which seems unlikely, or the system requires something turned on with a VACOM, but as it see's the AMI and DAB straight away, seems unlikely.Thanks again.
  9. Re: AMI fitted but issue. Any help please
    46 Post(s)
    You don't need the AMI coded, 510K is the one I use in my A3 without issues.
  10. Re: AMI fitted but issue. Any help please
    Sep 2011
    MMI 2G is 4F0 051 510 L Link:- AUDI A6/AVANT [A6] (EUROPE) 2005 [4F-5-000 001 >>]: ACCESSORIES, INFOTAINMENT: 05746. GENUINE ACCESSORIES; CONNECTION FOR EXTERNAL; AUDIO SOURCES; USB HARD-DRIVE; USB MEMORY STICK; ADAPTER
    MMI 3G is 4F0 051 510 K Link:- AUDI A6/AVANT [A6] (EUROPE) 2009: ACCESSORIES, INFOTAINMENT: 05746. GENUINE ACCESSORIES; CONNECTION FOR EXTERNAL; AUDIO SOURCES; USB HARD-DRIVE; USB MEMORY STICK; ADAPTER
    Again IIRC from what posts I've read MMI2G not like 3G cables but not entirely sure but your VAG dealer can verify if L does supersede to K.
    4F0 051 510 L in EPC I use does not supersede to K, what EPC I use is not what I've linked in post.
    Now what works for Chris beware is a 2009 A3, and K is what he should use in what I checked plus on the web Link:- AUDI A3/S3/SPORTBACK/QU. [A3] (EUROPE) 2009: ACCESSORIES, INFOTAINMENT: 05746. GENUINE ACCESSORIES; CONNECTION FOR EXTERNAL; AUDIO SOURCES; USB HARD-DRIVE; USB MEMORY STICK; ADAPTER
    Yes IC number differ as mine is AMI USB cable not AMI iPod/iPhone and like Chris state AMI not need coding to work but does tidy car's coding setup if done. You may have noted in my AMI retrofit guide at first I didn't have correct wiring setup to designate AMI as media player 2 whilst having AMI & CD changer fitted and it didn't cause any malfunction in use.
  1. A6 AMI Fitted (whistle from speakers)
    By Kevin Walker in forum In Car Entertainment
    Last Post: 11-03-2013, 09:28 PM
  2. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  3. AMI - Cable Supply Issue
    By greeng4309 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-04-2010, 06:24 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. Replies: 1
    Last Post: 07-12-2008, 03:27 PM
