Thread: AMI fitted but issue. Any help please
Results 11 to 20 of 35
  1. Re: AMI fitted but issue. Any help please
    46 Post(s)
    Many moons ago when I had AMI fitted 510K worked in the A6 too.
  2. Re: AMI fitted but issue. Any help please
    Apr 2009
    Surrey
    174 Post(s)
    Do you know anyone with an Audi that has AMI (the Mk 6 Golf also uses the same cable if has the Media Interface fitted). You could then validate if the cable works or not. The dealer might let you try it in a car they have in on the site if you ask nicely
  3. Re: AMI fitted but issue. Any help please
    Sep 2011
    Lurking over a keyboard ...
    Why would this work? Link:- AMI (Audi Music Interface) – Cable Compatability Music | I Am Audi
    So as highlighted in link you must have had lastest firmware in your AMI for K cable to work otherwise a K cable in MMI 2G AMI with older FW you get error message.
    @Muppet_man only way to do AMI FW update is via USB stick/cable, link in post one of this thread active, Link:- Important ami update online DOWNLOAD
  4. Re: AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    I went to Audi today and they were able to confirm that 510 K was for an Audi Allroad, but they said it was for models from 2008 to 2010, which I suspect means 3G versions and not a 2G like mine. The stores did show 510 K as an updated part for a 510 L, but not for the years 2006 to 2007. It simply says that 510 L is for older iPod classic and older iPods but not iPhone compatible.
    The compatibility chart you kindly gave the link for was quite interesting although strangely, as you point out, it seems to say that the 510 K could be used with the 2G system if a software update is done. However I already have the latest version, so sadly that doesn't really help. I take it that by software they mean the same as firmware. I guess I could run the update discs again, but I doubt they would do anything since they have no items that come up with 'require update' letter. So it won't really install anything. It does say that - CAUTION: Consumer SW-update for the 2G AMI-MOST units are only possible with 2G AMI SW > 700 , however I'm not really sure I know what that means.
    Quote Originally Posted by gupsterg View Post
    Thanks for the link, I've downloaded the file, and will have to order a USB lead and give it a try. Although of course, if the USB lead doesn't work, I won't be able to load the new firmware!
    Quote Originally Posted by johnsimcox View Post
    Sadly they didn't have a car on site that would fit the bill.
    Once again guys, thanks very much for all of your input. Hopefully I will get to the bottom of this eventually.
    More Muppet than Man
  5. Re: AMI fitted but issue. Any help please
    Sep 2011
    My daily drive is a VW Crafter, SWMBO drives the A6. The DAB keeps her entertained, I can post u my USB lead, as long as u resend after use.
    IIRC my AMI was latest firmware/software and thus the linked file did nothing but I will check my VCDS logs as to what FW/SW in my AMI tomorrow afternoon as busy in morning.
  6. Re: AMI fitted but issue. Any help please
    Nov 2011
    Beccles, UK
    That is a very kind offer, however I found one on E-Bay last night with the same Q part number as yours for a fiver, so I've ordered it and hopefully will receive it soon. How do you check the firmware of the AMI?
    Thanks for your time.
  7. Re: AMI fitted but issue. Any help please
    #17
    Sep 2011
    Code:
    Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H20 0850
       Revision: 00000000
       Coding: 010000
       Shop #: WSC 00000 000 00000
       VCID: 2B5F2C474A12FA40A59
    No fault code found.
    Mine's version 850 firmware, besides VCDS log to see version/info you maybe able to see it in hidden menu (green/service) you can see SW/HW part numbers in log, hardware version is H20. It also shows as media player 2 due to be doing the wiring mod/coding as per the AMI retro guide I posted in how to section.
    There maybe a log of Chris's on forum but I'm sure he'll post one for you.
  8. Re: AMI fitted but issue. Any help please
    #18
    Nov 2011
    Beccles, UK
    I'm going out to see if I can look at those details without a VCDS as I don't have one. I have a Snap on Verus and an Ultra as well as an Omintec Pro, but frustratingly you can't do that with any of them!
    I haven't done the mod with the wire, but since I've tried the unit on its own without the CD in place, I guessed this would not be the reason for the malfunction.
    Roll on my USB lead arriving.
    Code:
       Revision: 00000000
       Coding: 010000
  9. Re: AMI fitted but issue. Any help please
    #19
    Sep 2011
    Here is something from google images for you ...
  10. Re: AMI fitted but issue. Any help please
    #20
    Nov 2011
    Beccles, UK
    It looks like mine is a very much older unit. The 4E0 035 785 part number doesn't end in 'K' like yours, and the version number of V170 and software of H09 seem to be much older. Maybe this is the issue? I hope it is able to take the USB update! Hopefully the lead will arrive tomorrow.
    I'll let you know.
  1. A6 AMI Fitted (whistle from speakers)
    By Kevin Walker in forum In Car Entertainment
    Last Post: 11-03-2013, 09:28 PM
  2. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  3. AMI - Cable Supply Issue
    By greeng4309 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-04-2010, 06:24 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. Replies: 1
    Last Post: 07-12-2008, 03:27 PM
