Thread: Daylight Running Lights - How to turn ON?
  1. Daylight Running Lights - How to turn ON?
    Sep 2014
    Manchester
    Just got a 2011 Alhambra. Want to turn the DRL's on but the instruction manual is not clear at all... Any suggestions?
    Ta.
  2. Re: Daylight Running Lights - How to turn ON?
    Feb 2013
    Gloucester
    57 Post(s)
    It will need doing by VCDS if they aren't standard. And it depends if your car can take the coding to enable it. Search the forum for "VCDS users map" and it will show who is near that can try for you.
  3. Re: Daylight Running Lights - How to turn ON?
    Sep 2014
    Manchester
    I think they're standard. What's VCDS?
  4. Re: Daylight Running Lights - How to turn ON?
    Feb 2013
    Gloucester
    57 Post(s)
    VCDS is a dealer level diagnostic tool you can buy. Let's you conduct diagnostic work as well as programming on your car. If you search this forum for VCDS users map it will show you people local to you who are willing to help you for a small donation.
  5. Re: Daylight Running Lights - How to turn ON?
    46 Post(s)
    If there is nothing in your MFD (multifunction display) then they will need enabled via VCDS in the BCM module.
  1. LED Daylight Running Lights......
    By srisport in forum Passat CC
    Last Post: 20-09-2012, 11:02 AM
  2. Please Help Daylight Running Lights
    By Teflon in forum Polo - Derby - Lupo - Fox
    Last Post: 30-12-2010, 03:56 PM
  3. Passat Daylight running lights
    By bjros in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-09-2009, 11:13 PM
  4. LED Daylight Running Lights
    By Stonkn in forum Audi A3 - Archive Topics
    Last Post: 18-12-2007, 12:49 PM
  5. Daylight Running Lights
    By happy2bhere in forum Passat - Archive Topics
    Last Post: 30-11-2006, 10:19 AM
