Thread: 2.0l tdi pd fault finally found. please read
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: how do i fix this?? please help
    #21
    Aug 2014
    essex
    I did see that although it doesnt end there. You need bolts. Seals. Gaskets and more to change a head
  2. Re: how do i fix this?? please help
    #22
    Aug 2014
    essex
    There is no oil going to the exhaust lifters causing them to not pump up. Gonna start new post to try figure it out.
  3. Re: how do i fix this?? please help
    #23
    Aug 2014
    essex
    Well this is unbelieveable.
    I have cured the fault with the audi.
    It was a tiny roll pin that had failed allowing the rocker shaft to spin freely thus making the oil holes face in the wrong direction.
    Its another example of how stupid these engines are.
    I aligned the shaft and fitted new roll pin and now i have oil to the tappets.
    Hopefully this was a human error causing the roll pin to be damaged and not another mechanical failure to add to the list for the 16v tdi
  4. Re: how do i fix this?? please help
    #24
    Aug 2014
    essex
    I can now report that the car starts better. Has less airbox noise. More airflow through the exhaust and better performance.
  5. Re: how do i fix this?? please help
    #25
    Oct 2017
    Navan
    Hi sorry to be a pain and reopen an old thread.... but..
    I appear to have the same problem. 07 BRE,C on the head, 140 k miles and springie/missing lifters, not sure if exhaust or inlet yet. Timing belt done just before I got it
    To pull the the tappets does the shaft slide forward out of the head and did you have to pull the front off the car.
    Do you have a link for New tappets etc
    Did you have To pull the head and check valves or just replace tappets
    Did you start a new thread I can look at
    Did you pull the sump to check go bits.
    Did it cure the problem. I'm not sure whether to fix or scrap it.
    Thanks..
  1. I finally found a Le Mans!
    By Happybiker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-09-2013, 11:10 AM
  2. Finally found it... My new Car
    By Schmittster in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2013, 01:27 PM
  3. Finally found my baby
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-08-2010, 04:42 PM
  4. finally found one
    By dansansome in forum Chat - Anything with wheels
    Last Post: 05-06-2008, 01:00 PM
  5. fault codes read + 1 found.
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2008, 07:11 PM
