Thread: how long can a damaged timing belt last?
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
  1. Re: how long can a damaged timing belt last?
    Aug 2011
    Meath
    and do you really randomly pull back the covers on the timing belt to check the condition of the belt.do you also turn the engine over slowly to check all the belt, as the chances of the damaged bit being in view are quite remote.
    in fact, i think you are just full if it and are making the whole thing up , but can't imagine why.
    Christ it's DSG's alter ego
    1 3 0
  2. Re: how long can a damaged timing belt last?
    Pembrokeshire
    22 Post(s)
    never wondered ho you never see me and dsg on at the same time eh ???
    1 2 0
  3. Re: how long can a damaged timing belt last?
    Aug 2011
    Meath
    Remember Mike & Bernie Winters? A very unfunny act. Anyway they were doing a show in Scotland one night and one of them went on with the dog. After 5 minutes of "jokes" with no audience response the other one cam on stage and a voice from the back of the hall said "oh ****, there's 2 of them"
    0 3 0
  4. Re: how long can a damaged timing belt last?
    Mar 2008
    High Wycombe
    If you can see the toothed timing belt from under the bonnet, you need a new timing belt cover, as every Audi I've ever owned has the belt hidden away to protect it from dirt, grease and grime. Persons 1 or 2 would also need to have removed the cover to have cut it.
    Unless you mean the serpentine / alternator / fan belt, which is visible from under the bonnet, but breaking/cutting it would be the (albeit fairly major) inconvenience of not having the power steering, air conditioning or battery charging until you replaced it, but not as expensive as new pistons, valves or cams.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
    0 3 0
  5. Re: how long can a damaged timing belt last?
    Sep 2009
    London/Bucks England
    I doubt its been cut. Its cracked through age and tension most likely. These belts arent designed to stretch and snap, they will just get dry, crack and then boom. Your lucky you have 1 cord left holding the belt together. Don't drive it, get a new belt. Job done.
    You will be most likely causing damage to someone's possession for no reason, I also don't condone criminal damage. Those belts are pretty tough, I would expect if you tried to cut it with any normal knife, it would leave a horrendous frayed mess and dusty evidence under your belt cover. Cracking under tension will generally give a neater break, exactly like breaking an eraser in half. Are we talking a chef knife here or bowie?
    I like a bit of knifey spoony.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
    0 3 0
  6. Re: how long can a damaged timing belt last?
    Aug 2011
    Meath
    Quote Originally Posted by SammoVWT View Post
    Bowie would burn it - ashes to ashes...
  7. Re: how long can a damaged timing belt last?
    #17
    Sep 2014
    sin city
    hmm.
    i got person 2 too admitt it after i sent email to the manufacturer whit picture of the belt and theire engineers said if i started the engine the belt would snap immidiatly. so it had to been cut after i stalled the engine..
    and here you go trolls
    yes i do leave my car unlocked, and person 2 have owned 2 audis c4 so he knew exactly where to go, and yes i do randomly check me engine bay sometimes it just strikes me to do so . and the bit about the chance of the cut being right under the inspection cover is the main reason i belive it was person 2.
    and infact, you can think i lie til the sun hits the sky
    cant understand how you guys can be so touchy,, person 2 tried to kill my car ? eye for an eye, is in the bible eaven !
  8. Re: how long can a damaged timing belt last?
    #18
    Oct 2005
    Is person 2 a friend?
    Glad you got it worked out, I've always wondered how Norwegian justice is served
    0 2 0
  9. Re: how long can a damaged timing belt last?
    #19
    Pembrokeshire
    22 Post(s)
    you have obviously deeply upset person 2. i just hope you are right and it wasn't person 1 after all, as person 2 may be a bit upset at you if you vandalise his car and may take revenge on you, maybe by setting fire to your car.
    1 3 0
  10. Re: how long can a damaged timing belt last?
    #20
    Aug 2011
    Meath
    It's been fun reading this however I'm just about to remove my timing cover just in case someone I might have annoyed has cut my timing belt. What a load of old pony
    0 4 0
  1. A4 TDi Aux belt damaged
    By Grover2000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2011, 12:18 AM
  2. Cam Belt damaged
    By awmw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 08:54 PM
  3. How long to change a timing belt [a4 b5 1.6]
    By chrismaher2007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2010, 12:08 AM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. Damaged Passat 1.9TDI PD 130bhp Engine Block. A Long'ish Post.
    By Studio54 in forum Passat - Archive Topics
    Last Post: 20-10-2006, 10:00 PM
