Thread: Longer starting when engine hot and knock noise
  1. Longer starting when engine hot and knock noise
    May 2007
    Liverpool
    My 56 1.9tdi is good with a couple of problems.
    I replaced the oil today and had a look round. When it's at slow speed and I apply the brake I get a knock noise. If I reverse then brake it's the same.
    Also so when starting the engine when hot it turns over a few more times before firing. Still fires and has never not started.
    1998 Audi A4 2.8 V6 quattro
  2. Re: Longer starting when engine hot and knock noise
    Jan 2006
    Slow starting is due to fuel not being injected below cranking speeds of 270rpm. If your starter motor is getting on a bit, this will be the cause, replace it and all will be well again. Mines (55 plate) being doing this for several years now, i just live with.
  3. Re: Longer starting when engine hot and knock noise
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I had this with a polo and cheap pads. Check your pads for looseness in the carrier brackets, pads rocking up / down in forward then reverse. Could be brackets worn if high miler or poor fitting pads if non oem or missing anti rattle springs. Could also be worn caliper sliding pins or loose caliper bolts depending on front or rear calipers. Worth checking out and finding cause for peace of mind though.
  4. Re: Longer starting when engine hot and knock noise
    Aug 2011
    Meath
  1. Please Help Golf mk4 starting problem when engine hot
    By flapajack in forum Golf MK4 - 1999 - 2004
    Last Post: 09-05-2011, 05:34 AM
  2. Please Help Trouble starting engine when hot !!
    By mercer2773 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2010, 07:10 PM
  3. knock knock knock dam noise
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2010, 11:19 PM
  4. Starting Sharan when engine is hot
    By jomaz in forum Touran - Sharan - Caravelle
    Last Post: 22-07-2007, 05:30 PM
  5. slow hot starting on tdi engine
    By mikesvw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2006, 07:20 PM
