Thread: Audi A6/4F 3,0TDI BMK 2006
  1. Audi A6/4F 3,0TDI BMK 2006
    Jan 2014
    Porsgrunn Norway
    Going to change brake pads in front,, and i see that pads are worn very different!
    on the inside pads are nearly gone but on outside it seem s like new
    And its the same thing on the other side too
    I have checked the caliper stempel and sliders seems to work fine
    Does anyone have this problems? And is there something wrong
    bussen
  2. Re: Audi A6/4F 3,0TDI BMK 2006
    Aug 2014
    derby
    Quote Originally Posted by bussen View Post
    bussen
    Suspect the pads will be seized in the carrier bracket, with the caliper having piston on one side only, the braking effort will force that side only.
    Make sure you strip everything down and give all items a thorough clean. Remove the pad carrier bracket and clean all old brake pad dust residue using a wire brush and/or some energy paper.
    Clean the slider pins with emery to remove any deposits.
    Check the discs for a lip & remove with a grinder if Ness. Make sure that they've not gone below min. thickness.
    Smear copper grease onto the rear faces of the pads & onto the tabs where they locate into the carrier brackets, lube the pins as well.
    Brakes should be stripped & cleaned & rebuilt in this manner once a year to prevent them getting seized up, but manufacturer's are only interested in saying how much % is left to go .......
  3. Re: Audi A6/4F 3,0TDI BMK 2006
    Jan 2014
    Porsgrunn Norway
    Quote Originally Posted by MattR77 View Post
    Thanks good info
    bussen
  1. Which Glow Plugs for 3.0TDI (BMK)
    By six_or_out in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2015, 10:17 PM
  2. Please Help 2006 Audi A8 D3 3.0tdi 'Sudden Power Loss'
    By meffe in forum A8 - S8 - V8
    Last Post: 18-06-2013, 12:11 AM
  3. 3.0 tdi p0299 code bmk engine 2006 low turbo pressure
    By lazyfecker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-12-2012, 07:51 PM
  4. Audi A3 2.0tdi 2006 breaking
    By NavA3 in forum Audi A3 - Archive Topics
    Last Post: 23-06-2008, 09:56 PM
