Thread: SPAL Alarm - indicators not blinking when turning alarm on/off
  1. Question SPAL Alarm - indicators not blinking when turning alarm on/off
    Jul 2014
    Malta
    Car model: VW Polo Classic (sedan) 1998 diesel 1.9 SDI.
    I have an issue with regards to the alarm/central locking but I'm not sure if this is the correct section to post it. Please bear with me.
    I have the following alarm installed (I have this key fob):
    When turning on the alarm my car used to lock itself and the indicators would blink three times. After fiddling with the fuse the indicators stopped blinking (but the car still locks). I told my car electrician about this and after testing out a couple of things he told me that possibly it could be that the alarm system needs a reset. He tried pressing the buttons on the key fob for X number of seconds with/without the key engaged but he couldn't fix the issue. He said I should try finding a way how to reset the system online, maybe through a manual or asking if someone knows what to press on the key fob.
    Any ideas? I just need to get the lights to work again when turning the alarm on or off.
    Thanks!
    PS: A red light flashes when I press on the keyfob, which means the batteries are running out on the key fob. Could this have a bearing on my problem too?
  2. Re: SPAL Alarm - indicators not blinking when turning alarm on/off
    Jul 2014
    Malta
    Dropbox - external_light.php.pdf
    I found this, but I am unsure which one of the functions is the "reset". Any clue?
  3. Re: SPAL Alarm - indicators not blinking when turning alarm on/off
    Oct 2005
    There's a slightly more comprehensive manual here > JayCorp Technologies - SPAL AS80 Remote Entry Kit < which, if I've read it correctly, explains how to enable certain functions, one of which is the indicator flash.
    Section L 6 also shows you how to reset programming.
  1. alarm/flashing indicators
    By dexter35yrs in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 12-06-2013, 01:52 PM
  2. lights / indicators alarm is not working !!!!
    By tippex in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2010, 04:28 PM
  3. Question Alarm Indicator LED stays on for 30 seconds before blinking
    By BlackSmoke in forum Golf MK5 - 2004 - 2009
    Last Post: 17-04-2010, 11:56 AM
  4. Alarm and Indicators
    By portovechios in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-10-2009, 05:13 AM
  5. alarm problems flashing indicators
    By malakoffone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2008, 10:11 PM
