Thread: Avant rear light cluster problem
  1. Avant rear light cluster problem
    Aug 2014
    United Kingdom
    When fitting a new rear/brake light bulb to the NS light cluster, the Halfords guy lost what appears to be a square nut into which the long plastic screw has to go to hold the cluster in place. I've tried to find a part number for this (Inchcape want £43 + to supply and fit...!) - but no luck. I thought if I can get hold of a nut I could take to Halfords and get him to fit it. He had already fitted the OS bulb with no problems so I'm hoping this should work.
    I hope this is clear - first posting so apologies if any errors. Grateful for any help.
    Thanks.
    Jeff
  2. Re: Avant rear light cluster problem
    Aug 2014
    United Kingdom
    OK done. It's called a panel nut and will cost about 37p.
    Thanks for considering.
    0 0 1
  1. A4 B6 Avant - what the plasic moulding above the rear light cluster called?
    By CLOUD1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2014, 11:05 PM
  2. 2008 A6 2.0TDI rear light cluster problem
    By actionman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2013, 09:46 PM
  3. Rear light cluster - connection problem?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-01-2012, 01:26 AM
  4. Water / Condensation - Avant Rear Light Cluster
    By eallin in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-03-2010, 09:45 PM
  5. Rear light cluster problem
    By B6Andy101 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-10-2009, 12:21 PM
