Thread: 2005 alhambra reference tdi-help needed please
  1. 2005 alhambra reference tdi-help needed please
    Apr 2009
    shropshire
    Hi all
    I have a 2005 Alhambra reference tdi
    recently when hitting 3k revs in 4th gear it goes into limp mode. turning off/turning on engine gets it back to normal until it hits that speed again
    I have plugged my obd reader and produces no codes.
    I never really noticed before, but when I turn ignition on and the cycle of dash lights comes on, there are some lights missing, including the check engine light.
    I have tried all the fuses and replaced any that I thought may have gone, and no joy at all with the exception of the missing esp coming on ocassionally.
    I know the limp mode may/should be throwing up some codes and maybe easier to get to the bottom of the problem if the car was actually able to display a check engine light
    Any help would be much appreciated
  2. Re: 2005 alhambra reference tdi-help needed please
    May 2014
    london
    it will be the turbo, egr valve. do a google search for lofty79 on the skoda forum, mr muscle, vnt turbo.
    I had the same issues with my sharan, a bit werid spraying mr muscle into a car. I did and it worked a treat, the car runs excellent, right through the rev range with not safe mode kicking in.
  1. alhambra 130 tdi 2005
    By nobelz66 in forum Alhambra
    Last Post: 19-01-2012, 04:39 PM
  2. advise needed please on 2005 passat tdi
    By kadul in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-07-2010, 11:39 AM
  3. vag-com/vcds user needed south manchester .2005 golf 2.0 tdi mkv..
    By joseph76 in forum VCDS - Help Requests
    Last Post: 25-04-2010, 05:25 PM
  4. audi a3 2005 tdi ,dash dump and skc code needed
    By hollow in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-03-2010, 11:49 PM
  5. How To remove display cluster 2005 alhambra 130 SX
    By ronvyoung in forum Alhambra
    Last Post: 02-03-2010, 06:24 PM
