Thread: Problem with key or starter?
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 63
  1. Re: Problem with key or starter?
    #31
    Nov 2012
    Somerset UK
    Gup, does that make you Hannibal or BA?? If the latter you'll need to get down to the barbers!
    I love it when a plan comes together!
  2. Re: Problem with key or starter?
    #32
    Sep 2011
    Lurking over a keyboard ...
    More like mad Murdoch! ...
  3. Re: Problem with key or starter?
    #33
    Nov 2011
    Berlin
    Could any body tell me where is terminal 50 relay? Cause when turning key, terminal 50 stays off, car won't start.
  4. Re: Problem with key or starter?
    #34
    Dec 2009
    Kent, United Kingdom
    Hi all. 2006 C6 A6 3.0tdi manual.
    This just happened to me. Stranded 100miles from home. Key in the ignition normally audibly disables the steering lock but nothing this time. MMI works, and obviously the door locks but no lights on dash and can’t start engine.
    I have no tools with me sadly. Checked all fuses on DS end of dash. The steering wheel was free to turn though, almost as if the steering lock was never on?
    First things first, where are said relays please?
  5. Re: Problem with key or starter?
    #35
    Oct 2020
    Scotland
    Quote Originally Posted by dan2485 View Post
    Look at this
    Just swap the relay with the other 370 relay to see if the relay has failed.
    Post up your engine code and gearbox type so that i look up the correct drawing for your car.
    If the relay swap does not give back the instruments then you are looking at a J518 module fault as the relay coil grounds via this module.
    If a J518 module fault then dig deep as the post on the net that i have seen quote over £1400 to have replaced, if you handy with tools this maybe less but a trip to Audi or a good specialist is needed for the CP removal.
    Dan
    Dan can you please explain all relays what in photo or samebody else ???
  6. Re: Problem with key or starter?
    #36
    Jul 2013
    76 Post(s)
    Which year of car are you looking for? as they change position in the relay carrier, also the engine and gearbox codes would help to get you the correct arrangement for your car.
    Dan
    2009/2010 2.0 TDIe SE
  7. Re: Problem with key or starter?
    #37
    Oct 2020
    Scotland
    Audi A6 (c6) 20007 , bre engine code ,140hp tdi, automatic gearbox. and where is terminal 50 relay .
    and so far I found 2 relay in Ecu box,1or 2 relay opposite I believe is glow plug relay ( engine compartment)
    1 in bonnet and 7relays what in picture.
  8. Re: Problem with key or starter?
    #38
    Oct 2020
    Scotland
    Are you founded ???
  9. Re: Problem with key or starter?
    #39
    Oct 2020
    Scotland
    Are you founded where is ?
    Quote Originally Posted by GTA View Post
  10. Re: Problem with key or starter?
    #40
    Jul 2013
    76 Post(s)
    Have you checked the airbag fuse (Battery isolation igniter) on the battery cable for the terminal 50 supply as this may have failed.
    The other relay that could cause you issues is the Terminal 75 relay as shown below.
    Dan
  1. resync key fob problem only one key...
    By rustictwist in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2011, 08:11 AM
  2. Starter motor problem
    By eve1973 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2009, 09:15 PM
  3. starter motor problem
    By nick daly in forum Bora - 1998 - 2005
    Last Post: 01-04-2008, 10:20 PM
  4. starter problem
    By carcav in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-02-2008, 12:49 AM
  5. Starter Problem
    By richardjb in forum Audi A4 - Archive Topics
    Last Post: 07-08-2007, 03:54 PM
