Thread: Problem with key or starter?
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 63
  1. Re: Problem with key or starter?
    #51
    Jul 2013
    76 Post(s)
    You have 3 wires, 2 of them are crimped together look at your picture.
    From your video is shows that the ignition side is good, you need to check the battery boost terminals for power and for heat as if hot then this will cause a high resistance and stop the current flowing.
    Car Battery issue/Positive terminal.
    Battery Voltages on an A6?
    Dan
    2009/2010 2.0 TDIe SE
  2. Re: Problem with key or starter?
    #52
    Oct 2020
    Scotland
    But terminal 50r relay circuit stays all time off
  3. Re: Problem with key or starter?
    #53
    Oct 2020
    Scotland
    Battery wires not hot not in engine compartment and boot .not melted and looks clean and no any signs of corrosion
  4. Re: Problem with key or starter?
    #54
    Jul 2013
    76 Post(s)
    Can you get a VCDS scan done?
    Dan
  5. Re: Problem with key or starter?
    #55
    Oct 2020
    Scotland
    Wednesday,30,December,2020,13:43:37:03954
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 20.12.0.1 HEX-V2 CB: 0.4529.4
    Data version: 20201125 DS322.1
    Ross-Tech: Home
    VIN: WAUZZZ4FX8N049346 License Plate:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53
    56 61 62 72
    VIN: WAUZZZ4FX8N049346 Mileage: 342940km-213093miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine Labels: User\03G-906-016-BRE.lbl
    Part No SW: 03G 906 016 MF HW: 03G 906 016 MF
    Component: R4 2,0L EDC G000CG 1142
    Revision: --H05--- Serial number:
    Coding: 0000076
    Shop #: WSC 66565 257 00032
    VCID: 73B3DB9447B5DFB37E0-8026
    2 Faults Found:
    006215 - Please check DTC Memory of ABS Controller
    P1847 - 000 -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 342942 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:12:03
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Bin. Bits: 00000100
    012292 - Relay for Low-Output Preheating of Coolant (J359)
    P3004 - 000 - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 342942 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:12:03
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101000
    (no units): 0.0
    Bin. Bits: 11011100
    Readiness: 0 0 1 1 X
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F9 910 155 B HW: 01J 927 156 JG
    Component: V30 01J 2.0l PD RdW 0010
    Revision: --H03--- Serial number: 00000000000311
    Coding: 0000001
    Shop #: WSC 02325 758 00200
    VCID: 2A0D06F0D0FFDE7B0D6-807E
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.clb
    Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
    Component: ESP8 front H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020856
    VCID: 6597B5CCF9613103E04-8030
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 42
    Mileage: 342942 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:12:11
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x001E
    Hex Value: 0x3E97
    Hex Value: 0x00FF
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 42
    Mileage: 342942 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:12:15
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x0021
    Hex Value: 0x4197
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Revision: 09010701 Serial number: 10601500877733
    Coding: 0000019
    Shop #: WSC 02323 758 00200
    VCID: 6393ABD4F7554F330E0-8036
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: Redir Fail!
    Part No SW: 4F0 910 769 H HW: 4F0 035 769 B
    Component: MMI Cockpit H55 0410
    Revision: C61030BE Serial number: AUZ6Z3G95230R1
    Coding: 0140002
    Shop #: WSC 00370 210 64492
    VCID: 323D1E90F82F96BBB56-8066
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000000861162
    Subsystem 3 - Serial number: 0112.09.070000000100010441ÿ
    Subsystem 4 - Serial number: 010441ÿ
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000000441028
    Coding: 0001044
    VCID: 1C61D0288AAB30CB8FA-8048
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0000101
    Shop #: WSC 02335 758 00200
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: Redir Fail!
    Coding: 0140002
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0TVUV-
    Coding: 0013381
    VCID: 290FF9FCD5F9D56304C-807C
    Subsystem 1 - Serial number: 6332CSME2E547764A
    Subsystem 2 - Serial number: 6342CSME2E515A234
    Subsystem 3 - Serial number: 6352QSME3B032915B
    Subsystem 4 - Serial number: 6362QSME39543261B
    Subsystem 5 - Serial number: 63734SME362F34371
    Subsystem 6 - Serial number: 63834SME3B13160B
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H02000 Serial number: 90054072320033
    Coding: 0102141
    VCID: 270BFFC4C3EDE313128-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 C HW: 4F0 920 951
    Component: KOMBIINSTR. M73 H16 0240
    Revision: 00200000 Serial number: 64714X497
    Coding: 2304458
    Shop #: WSC 80093 222 69422
    VCID: 2019E4D8A6C3142B532-8074
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B078318198
    Coding: E5519E5770220600
    Shop #: WSC 12345 123 12345
    VCID: 2D070DECE111C943E84-8078
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
    Component: MP3-Changer H46 0350
    Revision: 00046006 Serial number: AUZ5ZBG3471047
    Shop #: WSC 00000 000 00000
    VCID: 1869CC387E935CEBAB2-804C
    Address 37: Navigation Labels: Redir Fail!
    Coding: 0140002
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00-00000
    Coding: 0002586
    Shop #: WSC 02327 758 00200
    VCID: 2C0100E8DA0BC04BFFA-8078
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H25 0200
    Revision: 02000025 Serial number: 01063816790000
    Coding: 0000251
    VCID: 313F119CFD29ADA3CCC-8064
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 910 223 K HW: 4F0 035 223 L
    Component: Amp.-ASK-RD H07 0250
    Revision: S0900000
    Coding: 010000
    Shop #: WSC 02399 823 56573
    VCID: 2615F2C0C8E7FA1B29E-8072
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000469859
    Coding: 0001104
    VCID: 5EE59A20DC3762DB21E-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00-00000
    Coding: 0002586
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000131
    Shop #: WSC 02324 758 00200
    Address 56: Radio Labels: Redir Fail!
    Coding: 0140002
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000135672
    VCID: 2313EBD4B7D50F334E0-8076
    Subsystem 1 - Part No: 4F0 915 105 C
    Component: von VA0 2708080328
    Coding: 344630393135313035432056413032373038303830333238
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0002050
    VCID: 2E050AE0EC17B25BD1E-807A
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0002050
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.6V/12.7V)-----------
  6. Re: Problem with key or starter?
    #56
    Jul 2013
    76 Post(s)
    There is nothing on the scan that will prevent the starting of the car. Have you checked at the starter motor to see if you are getting power to the solenoid when the key is turned over?
    Is there a 12 v feed to the motor on the main power lead?
    Is the engine ground lead good?
    The ABS faults are standard when the battery has been replaced and will clear when the car is started and driven.
    The J359 fault relates to a the auxillary heater that your car has fitted, this could just be a 40A fuse blown (this located under the J519 Module).
    Another question that needs to be asked can you turn the engine over by hand to rule out a siezed engine?
    Dan
  7. Re: Problem with key or starter?
    #57
    Jul 2013
    76 Post(s)
    found this video which may help you.
    audi a6 ,a4 ,a8 no start fix and diognastic - YouTube
    Dan
  8. Re: Problem with key or starter?
    #58
    Jul 2013
    76 Post(s)
    J53 relay.JPGThis is the J53 starter relay (this is the terminal 50 relay).
    Dan
  9. Re: Problem with key or starter?
    #59
    Jul 2013
    76 Post(s)
    I hope that you are well and safe, did you get your issue sorted?
    Dan
  10. Re: Problem with key or starter?
    #60
    Aug 2021
    Portugal
    Hello everyone,
    my A6 C6 avant 2.0 tdi is "dead". Insert key and nothing happens. The main problem is that my garage is too narrow for a tow truck to come in and with the car dead is close to impossible to push it out. So I'm stuck, literally... like the car
    Tried jumper cables with other car, nothing changed.
    Removed the battery, took it to the shop. They tested, charged it overnight and said it was good to go.
    Next day, mounted the battery in the car nothing changed, except the installed component not valid warning when I turn the mmi on... I'm 99% sure it wasn't there before I removed/installed the battery.
    I went and purchased a vagcom, I've never used one befora.
    At first the car wasn't communicating, I tried the brake+hazards+high beams and it started the scan.
    1st scan fault codes almos everywhere.
    After clearing all the fault codes at once... and then clearing one by one, on the ones that I could access, this is what the car is left with:
    Sunday,08,August,2021,11:24:22:00009
    VCDS Version: 20.12.0.0 (x64)
    Data version: 20201124 DS322.0
    Ross-Tech: Home
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
    62 72 76 77
    Mileage: 334540km-207873miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    47-Sound System -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
    56-Radio -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Revision: 09010701 Serial number: 10601500809550
    Coding: 0000131
    VCID: 63CFF24EA255B19C7E-8036
    Cannot be reached
    Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
    Revision: 00000052 Serial number: 00000030252450
    Coding: 0000276
    VCID: 1C3D89B2DFABCE64FF-8048
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Coding: 0000101
    VCID: 31634806A829530CBC-8064
    Subsystem 1 - Component: Fehler Lin-Slave 01
    Subsystem 2 - Component: Fehler Lin-Slave 02
    Cannot be reached
    Address 15: Airbags
    Cannot be reached
    Cannot be reached
    Part No SW: 4F0 910 900 C HW: 4F0 920 901 G
    Component: KOMBIINSTR. M73 H16 0220
    Revision: 00100000 Serial number: 645731D67
    Coding: 3328158
    VCID: 2045BD42F3C3EA8423-8074
    Address 19: CAN Gateway Labels:. 4F0-910-468.clb
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 1300807613820C
    Coding: ECFE53C41B1104
    Shop #: WSC 02334 758 00200
    VCID: 2757A65E96ED1DBC62-8072
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Revision: Serial number: 00000000450315
    Coding: 0001104
    VCID: 5EB9C3BA89379C7451-800A
    Cannot be reached
    Cannot be reached
    Address 56: Radio
    Cannot be reached
    Revision: 00000000 Serial number: 00000000094066
    Shop #: WSC 00084 261 54941
    VCID: 234FB24EE2D5F19C3E-8076
    Component: von VA0 2706070021
    Coding: 344630393135313035432056413032373036303730303231
    1 Fault Found:
    02273 - Quiescent Current Stage 2
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 334545 km
    Time Indication: 0
    Date: 2007.03.13
    Time: 13:16:51
    Cannot be reached
    Cannot be reached
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
    Component: Parkhilfe 4-Kan H09 0060
    Revision: 00H09000 Serial number: 06230717406098
    Coding: 0001016
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone
    Cannot be reached
    End-------------------------(Elapsed Time: 02:35)--------------------------
    Thanks in advance for all the help you could give me.
  1. resync key fob problem only one key...
    By rustictwist in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2011, 08:11 AM
  2. Starter motor problem
    By eve1973 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2009, 09:15 PM
  3. starter motor problem
    By nick daly in forum Bora - 1998 - 2005
    Last Post: 01-04-2008, 10:20 PM
  4. starter problem
    By carcav in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-02-2008, 12:49 AM
  5. Starter Problem
    By richardjb in forum Audi A4 - Archive Topics
    Last Post: 07-08-2007, 03:54 PM
