Thread: Problem with key or starter?
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
  1. Re: Problem with key or starter?
    #21
    Jul 2013
    76 Post(s)
    Look at this
    Just swap the relay with the other 370 relay to see if the relay has failed.
    Post up your engine code and gearbox type so that i look up the correct drawing for your car.
    If the relay swap does not give back the instruments then you are looking at a J518 module fault as the relay coil grounds via this module.
    If a J518 module fault then dig deep as the post on the net that i have seen quote over £1400 to have replaced, if you handy with tools this maybe less but a trip to Audi or a good specialist is needed for the CP removal.
    Dan
    2 1 0
  2. Re: Problem with key or starter?
    #22
    Nov 2010
    Middle of nowhere
    Holy cr@p that just worked & I saved myself an expensive trip getting towed to the Audi garage! Car started straight away & component protection message has gone.
    What does the other 370 relay do? I noticed an ESP msg flash up briefly on the dash.
    1 1 0
  3. Re: Problem with key or starter?
    #23
    Sep 2011
    Lurking over a keyboard ...
    I just did video for you which was uploading my MVB's showing term 15 on my car has voltage but yours doesn't
    Quote Originally Posted by staffop1 View Post
    That is in post 19 of this thread.
    Quote Originally Posted by dan2485 View Post
    I did check his past posts, he has a 2.0 TDi 59 plate PS170
    Address 19: CAN Gateway (4F0 907 468 M)
    21:39:57 Group 001: Power Supply
    0.00 V Voltage (Terminal 15)
    11.70 V Voltage (Terminal 30)
    My MVB 200 in module 19 is same as your MVB 001 in module 19, as my car is 2005 yours 2009, see how you had 0.0v at term 15?
    Not sure if that tells me the ignition switch is fine or not!, I get no lights on the dashboard turning the key..
    MVB 23 in module 05 would have shown you that IMO.
    If the relay sway does not give back the instruments then you are looking at a J518 module fault as the relay coil grounds via this module.
    This was what I had been thinking but didn't wanna say as .
    J518 function is master unit of CP , view ssp 326 page 19, so I think lack of volts term15/J329 was creating message but as just an owner!
  4. Re: Problem with key or starter?
    #24
    Nov 2010
    Middle of nowhere
    Engine code is CAHA & gearbox LDV btw
  5. Re: Problem with key or starter?
    #25
    Jul 2013
    76 Post(s)
    Don't worry about the other relay just replace it with a new one.
    Thank Gups for pointing you towards the relay.
    Dan
    2 1 0
  6. Re: Problem with key or starter?
    #26
    Sep 2011
    ..... .... I am really glad it has worked for you mate! ....
  7. Re: Problem with key or starter?
    #27
    Jul 2013
    76 Post(s)
    Put the new relay in the J329 position to avoid the other relay failing.
    370 relay Part No is 8D0591253.
    Buy a new one even though a used one is £3 on ebay if it cost you £20 from Audi then its money well spent.
    Dan
  8. Re: Problem with key or starter?
    #28
    Sep 2011
    Hi Dan,
    I put too much content in post 19, but P/N is in there mate.
    Quote Originally Posted by gupsterg View Post
    P/N for J329 4H0 951 253 please do double check this with vag dealer.
    ATB
    G
  9. Re: Problem with key or starter?
    #29
    Jul 2013
    76 Post(s)
    i just Google searched an Audi 370 relay that's how i got the no, right or wrong?.
    Top work to yourself as this could have cost him loads.
    Dan
  10. Re: Problem with key or starter?
    #30
    Sep 2011
    SDC code/VAG descriptors don't work that way from what I've come across, some do others don't, very hit miss.
    I'm just glad staffop1 got a good result, if I'd never had such a ball ache of a car I don't think I'd have been on forums! LOL
  1. resync key fob problem only one key...
    By rustictwist in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2011, 08:11 AM
  2. Starter motor problem
    By eve1973 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2009, 09:15 PM
  3. starter motor problem
    By nick daly in forum Bora - 1998 - 2005
    Last Post: 01-04-2008, 10:20 PM
  4. starter problem
    By carcav in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-02-2008, 12:49 AM
  5. Starter Problem
    By richardjb in forum Audi A4 - Archive Topics
    Last Post: 07-08-2007, 03:54 PM
