Thread: Problem with key or starter?
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 63
  1. Re: Problem with key or starter?
    Aug 2013
    Embra
    Quite a few there - low battery ?
  2. Re: Problem with key or starter?
    Nov 2010
    Middle of nowhere
    The fresh air blower is a pre-existing fault I'm aware of where the fan doesn't always work. From googling that error it looks like an expensive fix as the whole fan unit has to be replaced.
    Not sure about the flat battery as it was showing 12.1v on the multimeter when I checked.
  3. Re: Problem with key or starter?
    Aug 2013
    Embra
    It was just a thought, monitoring in case it happens here...
  4. Re: Problem with key or starter?
    Nov 2012
    Somerset UK
    I had half of those showing when my alternator failed...new regulator needed....but my battery was completely dead
    Did you save & clear the DTC's several times and were any of them disappearing?
  5. Re: Problem with key or starter?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by staffop1 View Post
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601409590
    Coding: 0000147
    Shop #: WSC 02323 785 00200
    VCID: 2541EB72EC24F336C81-8070
    Subsystem 1 - Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    1 Fault Found:
    00576 - Terminal 15
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01111001
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 34
    Mileage: 161293 km
    Time Indication: 0
    Date: 2014.06.22
    Time: 12:06:50
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L0990780A0
    Coding: 000B03
    Shop #: WSC 02391 823 56573
    VCID: 39793702B09C67D69C9-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    1 Fault Found:
    00576 - Terminal 15
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 69
    Mileage: 161261 km
    Time Indication: 0
    Date: 2014.06.21
    Time: 12:44:13
    Freeze Frame:
    Bin. Bits: 00110
    Voltage: 12.50 V
    Count: 8
    Looking at your scan/symptom you describe concerning gaining entry/starting vehicle my £ is on to investigate J329 Terminal 15 relay.
    J329 is Terminal 15 voltage supply relay it is directly linked into J518 Entry and start authorisation control unit plus is part of starter, alternator, starter motor relay circuit diagram.
    From what I've looked at it is behind trim where your knee would be when sitting in drivers seat.
  6. Re: Problem with key or starter?
    Nov 2010
    Middle of nowhere
    Couldn't see a J329 relay, this is all I have behind the panel in the footwell.
    I've fully charged the battery just to make sure and also cleared the DTCs but the component protection message is still there on the MMI and in the VCDS scan.
    Problem I have is I can't even move the car or take the car out of 'Park', it's completely disabled!
  7. Re: Problem with key or starter?
    #17
    Sep 2011
    J329 is the SDC code for relay, it will not be printed on relay. If you ask at an Audi dealer parts dept they will supply relay from that code plus cross ref with VIN , etc.
    Sorry I should have given you a part number/location on the coupling station, later when by PC will check/post
  8. Re: Problem with key or starter?
    #18
    Nov 2012
    Somerset UK
    This may be useful
    2006 Jetta TDI - Quits for no reason - TDIClub Forums
    Although the J329 is clearly diferent in your car.
  9. Re: Problem with key or starter?
    #19
    Sep 2011
    @staffop1, may I first start in saying I'm just an owner, I have diddly squat professional experience of VAGS .
    I'm helping as I hope by helping someone, someone will help me when I have a problem .
    Now that's out of the way! what have I dug up for you to do some meddling with!
    Red line = J329 , green line is same type of relay from what I've viewed, that is supposed to be J360 High heat output relay and is in the circuit engine speed sender, radiator fan control unit, low heat output relay, high heat output relay, radiator fan.
    Attachment 24939
    Next some measuring blocks you could view:-
    Module 05 MVB 1 Data window 1 , MVB 3 data window 2 , MVB 6 data window 2 , MVB 7 data window 2 , MVB 23 data window 23
    Ref Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Access/Start Auth. J518
    Module 19 MVB 001
    Ref Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Gateway J533
    Something about the J329 faults, Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Without address word J329
    Now DTC 00576 is explained as :-
    VAG Error Code: 00576
    Fault Location:
    Terminal 15 - Electrical Fault in Circuit/Implausible Signal - Intermittent
    Possible Cause:
    Power Locks operating at random while driving.
    Radio doesn't turn off when key is removed from Ignition.
    Battery drain.
    No audible confirmation from alarm horn when arming alarm system.
    On the Eos, the front windows may drop down a little if rolled up all the way.
    Defective Ignition Switch (Electrical Portion).
    Wiring harness issue.
    Possible Solutions:
    Replace the Ignition Switch (Electrical Portion).
    Repair damaged wiring harness.
    Now I'm hoping by doing MVB's in module 05 you'll be able to see something which tell you that ignition switch is fine.
    In the link for J329 faults you will see replace CU, I'm assuming that mean Control Unit, I did storta read up what CU this may relate to but will hold off for now.
    After you cleared DTC's did same faults come up? P/N for J329 4H0 951 253 please do double check this with vag dealer.
    PS for other DTC's you can use KeithUK's ( ) great APP Link:- https://www.vwaudiforum.co.uk/forum/s...II-Error-Codes
    1 1 0
  10. Re: Problem with key or starter?
    #20
    Nov 2010
    Middle of nowhere
    So this is what comes back from the measuring blocks for Modules 5 & 19:
    Address 05: Acc/Start Auth. (4F0 910 852 B)
    21:34:48 Group 001: Terminal Status
    Term 15 Off Status Terminal 15
    3.0 (no units)
    OFF Status Terminal 75X
    Term 50 Off Status Terminal 50
    21:34:48 Group 002: Entry and Start Authorisation Buttons
    OFF Start Auth. Button (E408) ON
    OFF Start Auth. Button (E408) START
    OFF Start Auth. Button (E408) STOP
    00000000 Door Touch Sensors
    21:34:48 Group 003: Ignition Switch (E415) I
    ON Status S-Contact
    ON Status Terminal 15
    OFF Status Terminal 50
    Thursday,10,July,2014,21:40:11:50677
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    Address 19: CAN Gateway (4F0 907 468 M)
    21:39:57 Group 001: Power Supply
    0.00 V Voltage (Terminal 15)
    11.70 V Voltage (Terminal 30)
    Not sure if that tells me the ignition switch is fine or not!, I get no lights on the dashboard turning the key..
  1. resync key fob problem only one key...
    By rustictwist in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2011, 08:11 AM
  2. Starter motor problem
    By eve1973 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2009, 09:15 PM
  3. starter motor problem
    By nick daly in forum Bora - 1998 - 2005
    Last Post: 01-04-2008, 10:20 PM
  4. starter problem
    By carcav in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-02-2008, 12:49 AM
  5. Starter Problem
    By richardjb in forum Audi A4 - Archive Topics
    Last Post: 07-08-2007, 03:54 PM
