Thread: Autel MaxiService VAG505 OBD Scan tool
  1. Autel MaxiService VAG505 OBD Scan tool
    Apr 2013
    donadea co kildare
    I'm looking at the Autel MaxiService VAG505 OBD scan tool. Does anyone know if this can be used on a 2007 A6 to reset the service interval, and to wind back the electronic parking brake motors for a brake pad change. I can do the latter mechanically, but I'd like something easy to use to reset the service interval, and if I can use it to change the pads, all the better. It's currently available for less than a 100 quid.
    2007 A6 TFSi Multitronic Auto Cream Leather but only a single CD player!(now with Dension GW500 Mp3 and Ipod/Iphone playback !!)( now for sale)
    2015 A6 3l quattro business edition, more cream leather, nav high, etc.
  2. Re: Autel MaxiService VAG505 OBD Scan tool
    Jul 2013
    56 Post(s)
    Your better off saving up a little bit more and getting a genuine VCDS cable.
    263 for a new cable and the VCDS software is free from Ross-Tech.
  3. Re: Autel MaxiService VAG505 OBD Scan tool
    Nov 2008
    Cramlington,Northumberland
    10 Post(s)
    Agree, get VCDS. I bought an Autel a while ago and it doesn`t pick up all codes as the VCDS would, and you can do your rear pads etc!
    Alan.
    APR ST1
  4. Re: Autel MaxiService VAG505 OBD Scan tool
    Apr 2013
    donadea co kildare
    Quote Originally Posted by Alan02 View Post
    Alan, are you saying the Autel can rewind back the parking brake on an A6?, or are you saying you need VCDS. I'm getting conflicting info from some suppliers. The supplier obdtool.co.uk ( a chinese based supplier notwithstanding the URL) has a download of the manual which gives the EPB procedure, but when I emailed them in regard to my 2007 A6 they said it would only reset the service interval, but not do the EPB. Another Ebay seller (beat-the-garage on eBay) says it will work. Have you tried it on your Avant? It would be worth the purchase price for these two tasks, after that it would be nice to have, but I really don't need to get full VCDS, Most of my repairs in the last year (Thermostat, Door lock, Power window switch, ) didn't require a scan. In the case of the thermostat failure, the temperature gauge stops working as a result of the ECU detecting slow heatup, and this fault can be cleared by disconnecting the battery (having put in a new stat). I've got Torque via bluetooth for a huge amount of data, but I'd like the reset.
    Further to this, this German thread, http://www.motor-talk.de/forum/funkt...-t4353010.html , seems to indicate that the EPB function is supported in the A6 C6 series (also known as A6 4F). I think I'll take the plunge.
  1. scan tool reading everything except the ECU.?
    By Jaecee in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 22-01-2014, 08:59 PM
  2. VCDS or OBD tool to reset Airbag light - South Manchester
    By gazza007 in forum VCDS - Help Requests
    Last Post: 31-07-2012, 11:30 AM
  3. Vgate VS450 VW Group Diagnostic OBD Tool
    By willielavery in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 10-01-2012, 10:45 PM
  4. VAG OBD-2 re set tool...
    By Scalipered in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2008, 09:33 PM
  5. OBD scan tool will not scan 98 jetta 2.0 (bora uk)
    By Romb4557 in forum Bora - 1998 - 2005
    Last Post: 17-01-2007, 05:29 AM
