Thread: Engine Fault Warning Light - 1.6TDi
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
  1. Engine Fault Warning Light - 1.6TDi
    Feb 2011
    Herts, UK
    In the last 3-4 weeks I have had an engine fault warning light illuminate on the dash. When this happens there is no loss of performance and when I usually switch off the engine and drive the car again the warning light does not come on. It's happened 3 times now with the same pattern of coming on and not reappearing with the next engine start.
    Mileage is 42000.I know its vague but I this the precursor to any known problems?
    2010 Golf Plus 1.6TDi SE Bluemotion
  2. Re: Engine Fault Warning Light - 1.6TDi
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Well Bob you need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Engine Fault Warning Light - 1.6TDi
    Feb 2011
    Herts, UK
    I would have to find someone with the equipment to do that Keith as I don't have it. The only people I know who have one is the local VW dealer and I don't know if they would share the codes with me.
  4. Re: Engine Fault Warning Light - 1.6TDi
    Jun 2010
    Nottingham UK
    Fingers crossed you've not got the infamous EGR valve trouble at 42k..........but 3x times with the light is not the usual sp/form.......
  5. Re: Engine Fault Warning Light - 1.6TDi
    Jun 2014
    Where in hearts are you bud, I have vcds and am near bedford, happily do a full scan for you find any codes logged
  6. Re: Engine Fault Warning Light - 1.6TDi
    Feb 2011
    Herts, UK
    Quote Originally Posted by Berisford View Post
    I hope it's not EGR problems too.
  7. Re: Engine Fault Warning Light - 1.6TDi
    Feb 2011
    Herts, UK
    Quote Originally Posted by Rabid View Post
    What a gent! I am in Welwyn Garden City
  8. Re: Engine Fault Warning Light - 1.6TDi
    Sep 2009
    12 Post(s)
    We do have Vehicle Diagnostics Equipment - VCDS Information Only on here if you want to search for someone in your area?
  9. Re: Engine Fault Warning Light - 1.6TDi
    Feb 2011
    Herts, UK
    I just contacted my local VW dealer and it was a fruitful call. The warning light that has come on is the glow plug warning light, but the cost of investigating the problem starts at £138 just for the diagnostic! Ouch!!!
  10. Re: Engine Fault Warning Light - 1.6TDi
    Jun 2014
    Big ouch, my offer still stands, but I am in Bedford, may be someone on here closer, I don't pretend to be an expert, but I have run a full scan on mine and found a few faults.
  1. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. intermittent turbo fault, engine warning light.
    By Leigh1972 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2012, 07:48 PM
  4. Please Help Passat 1.8T Engine/Fuel/Ignition Fault - Catalyst Warning light on dash illuminated
    By Captain Babble in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 05:33 PM
  5. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
