Thread: Engine Fault Warning Light - 1.6TDi
Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
  1. Re: Engine Fault Warning Light - 1.6TDi
    #41
    My 2012 Golf 1.6tdi has just had this warning light up apparently its a tempreature sensor that needs replacing a two hour job
  2. Re: Engine Fault Warning Light - 1.6TDi
    #42
    Feb 2011
    Herts, UK
    I expect yours was under warranty Ian?
    2010 Golf Plus 1.6TDi SE Bluemotion
  3. Re: Engine Fault Warning Light - 1.6TDi
    #43
    Yes it is ive been out tonight and catalitic converter light is on it shouldnt be happening to a two year old car with 14000 on the clock
  4. Re: Engine Fault Warning Light - 1.6TDi
    #44
    Feb 2011
    Herts, UK
    Here's an update to my situation. My supplying dealer wanted to charge £99 to carry out the diagnostic. I had a long chat with one of the service advisers who after speaking to her manager was able to reduce the price to £49, which I was happy with. The car went in this morning and the fault was traced to a defective DPF sensor. I was quoted £218, including the diagnostic charge, to do the work. I asked about customer care, given the car is just under 4 years old, and the receptionist popped inside the office and emerged about a minute later to say they could do the repair on a basis of 70/30, with me paying 30% of the total bill. So, for a grand total of £78.50, including the diagnostic charge, my car is now sorted!
    Thank to all who helped out on this one, with the exception of Uwe on the Ross Tech forum, who showed himself up as a complete bell end with his attitude.
  5. Re: Engine Fault Warning Light - 1.6TDi
    #45
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Bob_S View Post
    Do you have a genuine VCDS cable?
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  6. Re: Engine Fault Warning Light - 1.6TDi
    #46
    Feb 2011
    Herts, UK
    No Keith, I don't.
  7. Re: Engine Fault Warning Light - 1.6TDi
    #47
    Mar 2017
    Stoke Poges, UK
    Hi all,
    I've had my Golf TDi 1.6 mk6 from new.
    I bought it back in 2010 and it's now up to 92k on the clock.
    Last year the Glow Plugs Warning light started flashing a few weeks later on the Engine Management light came on. The car ran fine, no limp mode issues. I had a diagnostic session done on the car, turned out one of the lamba sensors and glow plugs needed to be replaced
    The Glow Plugs light would come on and off, the Engine Management light would flash on occasion.
    12 months later I got round to having the sensor and glow plugs replaced.
    As I drove the car out of the garage the Glow Plugs light started blinking and then later the Engine Management light came on permanent.
    The garage advised that it was one of the other sensors that also needed to be replaced, however on further inspection, they advised that it is the EGR valve that needs to be replaced. Again there is no problem with the car - it runs fine, no loss in power.
    I'd like to ask the fellow members here - has anyone else had the Engine Management light on permanent and the Glow Plugs light starts flashing after 2 mins of driving (for 30 secs), yet the car still runs fine?
  8. Re: Engine Fault Warning Light - 1.6TDi
    #48
    Mar 2017
    Manchester
    Heh Bob. Engine management light coming on is a known problem with VW older vehicles. I've had an old Polo, 1.6 Golf S and a 1.9 Jetta. My mother had a 1.4 Polo and my two mates both had 2.0 Golf and Golf GT all with engine management lights coming on at some stage and in most cases staying on. Numerous garage trips, and even an argument with a dealer under a warranty timeframe didn't resolve it. Until my garage which the head mechanic owned a Polo and a Jetta did the computer checks. Its seems to be an overzealous sensor on the exhaust system. Nothing serious. I drove all three of the cars I had with it on permanently. Although, I hope it doesn't come on my 2011 Golf Match. But as you can see it hasn't deterred me from VW.
  1. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. intermittent turbo fault, engine warning light.
    By Leigh1972 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2012, 07:48 PM
  4. Please Help Passat 1.8T Engine/Fuel/Ignition Fault - Catalyst Warning light on dash illuminated
    By Captain Babble in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 05:33 PM
  5. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
