Thread: A6 Mist Washer Jets
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
  1. A6 Mist Washer Jets
    Nov 2013
    London
    Hi all,
    So after spending good part of this afternoon clearing out the triple screen washer jets on my car and topping up with screen wash from TPS, wanted to know if we could change them to the mist jets as I find the triple jets waste too much screen wash. I've looked high and low and can only find posts relevant to the A4.
    Is it possible we can retrofit it to a 2011 C6?
    Audi A4 B6. Washer jets: fan spray - YouTube
  2. Re: A6 Mist Washer Jets
    46 Post(s)
    Parts from a B5 Passat I believe are a direct replacement. I have them on my A3 and they're so much better than the jet type.
  3. Re: A6 Mist Washer Jets
    Nov 2013
    London
    Thanks Chris, do you know what the part numbers are? Also are they a direct replacement for the C6? I need the heated ones
  4. Re: A6 Mist Washer Jets
    46 Post(s)
    Plenty of info on the WWW, there are non-heated and heated versions, the heated units are the dearer ones.
  5. Re: A6 Mist Washer Jets
    46 Post(s)
    I'll try them in my A6 and let you know if they're direct fitment
  6. Re: A6 Mist Washer Jets
    Nov 2013
    London
    Thanks Chris! They should have made them as standard IMHO, a simple but so effective mod
  7. Re: A6 Mist Washer Jets
    46 Post(s)
    Totally agree!
    A6 is away tonight but I'll let you know tomorrow some stage.
  8. Re: A6 Mist Washer Jets
    Nov 2013
    London
    Thanks again Chris! On another note, does anyone know how big the screenwash reservoir is on the A6? I only ask as i wanted to get the right dilution of VAG screenwash.
  9. Re: A6 Mist Washer Jets
    46 Post(s)
    It's at least 4L from empty I'm sure, dilution rate doesn't have to be exactly correct you know.
  10. Re: A6 Mist Washer Jets
    Nov 2013
    London
    Yes definitely more than 3.5 litres, so either 4, 4.3 or 5 litres. I only ask as I poured1 litre of VAG screenwash and topped up water, but seems too strong when used.
  1. Washer Jets...
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2014, 12:46 PM
  2. Question Washer Jets
    By Rusk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2011, 06:51 PM
  3. Washer jets
    By bakili in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-12-2010, 05:19 PM
  4. changing the washer jets to wide spray jets
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2010, 08:54 AM
  5. Washer Jets
    By Moro Anis in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-04-2008, 01:45 PM
