Thread: A6 Mist Washer Jets
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
  1. Re: A6 Mist Washer Jets
    #31
    Nov 2013
    London
    Ah bugger! Well I'm sure you'll find a way! Also is it a direct replacement? Shouldn't take more then 5mins to change if so
  2. Re: A6 Mist Washer Jets
    #32
    Nov 2009
    46 Post(s)
    30 seconds each side. Don't think theres a way round it unless you cut the bonnet (!).
  3. Re: A6 Mist Washer Jets
    #33
    Nov 2013
    London
    Hmmm maybe try and turn the sprayer 180 degrees as it originally meant to be on the scuttle panel and not upside down on the bonnet.
  4. Re: A6 Mist Washer Jets
    #34
    Nov 2009
    46 Post(s)
    You can't, its one complete unit.
  5. Re: A6 Mist Washer Jets
    #35
    Nov 2013
    London
    Found this on Audi sport
  6. Re: A6 Mist Washer Jets
    #36
    Nov 2009
    46 Post(s)
    Thats for the prefacelift A3 and A4 B7 which has the wrong sized recess. The A6s recess is fine, no gluing needed.
  7. Re: A6 Mist Washer Jets
    #37
    Jan 2015
    New Malden, U.K.
    This is probably me being a little dim, on a A6 C6 does this fit properly?
  8. Re: A6 Mist Washer Jets
    #38
    Nov 2009
    46 Post(s)
    Quote Originally Posted by k992061 View Post
    Quote Originally Posted by me
    Ok sitrep, they do fit and they do work but as the A6s are mounted on the bonnet rather than the scuttle for the B5 and A3 the bonnet is blocking some of the spray even with the nozzle screwed right up (any further down the wiper arm blocks the spray!)
    In case you missed it.
  9. Re: A6 Mist Washer Jets
    #39
    May 2008
    Lincoln UK
    Does anybody have a part number for these fan spray alternatives to the 3 pistol type I have currently? They keep getting blocked.
  10. Re: A6 Mist Washer Jets
    #40
    Feb 2013
    Gloucester
    57 Post(s)
    Have a look at the A7 section. Part is the same, I wrote a how to on there which I think is a sticky
    Sent from my iPhone using Tapatalk Pro
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  1. Washer Jets...
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2014, 12:46 PM
  2. Question Washer Jets
    By Rusk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2011, 06:51 PM
  3. Washer jets
    By bakili in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-12-2010, 05:19 PM
  4. changing the washer jets to wide spray jets
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2010, 08:54 AM
  5. Washer Jets
    By Moro Anis in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-04-2008, 01:45 PM
