Thread: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
Results 1 to 9 of 9
  1. Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Aug 2013
    Maidenhead - Berks - UK
    I have just purchased a 2011 (2010 Model Year) A6 Avant and believe it has MMI 3G (Standard) and really want to add DAB to it, I've read that this can be done but having red about CP (Component Protection) I decided to try and get a genuine New DAB unit from Audi only to be told that one is not available for My car (Except the Pure Dab Add on system).
    I looked @ my existing tuner which is 4G0 035 056 and I "Think" from most of My reading that a suitable DAB tuner for Mine should be a 4G0 035 061 (D).
    Can anybody with knowledge on this please let me know if this is possible or not and / or any clues on how to proceed.
    Lyndon
  2. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Apr 2009
    Surrey
    172 Post(s)
    Doable and a search on web will find a number of people who will install it for you. here is another option http://www.kufatec.co.uk/shop/en/aud...f-mmi-3g-avant
  3. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Aug 2013
    Quote Originally Posted by johnsimcox View Post
    Doable and a search on web will find a number of people who will install it for you. here is another option DAB Digital Radio - Retrofit - Audi A6 4F - MMI 3G - Avant-37568-1_M
    Thanks for that but I know people like Kufatec will / can do it but I really would like to do it myself as I'm an engineer and would like the satisfaction of knowing what / how it works etc plus it will obviously save money if I do it myself and also I'm a bit of a perfectionist & I know if I do it the job will be done 100% correctly and sometimes other people don't take quite as much care and concenrate on the fine details so much.
    Lyndon
  4. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Apr 2009
    Surrey
    172 Post(s)
    Quote Originally Posted by Anorak_Stan View Post
    Lyndon
    The link I put up for the stuff from Kufatec is only the parts you can fit it yourself. As you have an Avant the DAB aerial is already in the rear passenger side window so only need to add the unit into the cage at the rear of the car connect the aerial and (possibly) recode the car to recognise the DAB unit but even that may not be necessary
  5. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    46 Post(s)
    Search for "the day the music died" and you'll see Neil's thread where he done what you're wanting to do.
  6. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Aug 2013
    Thanks, I thought the Kufatec was installed equipment only.
    I will go and have a closer look and see what that equipment conststs of and what I need to do for Aerial on My car and hope if it needs coding it's not too difficult !
    Thanks Again
    Lyndon
  7. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Aug 2013
    Wow that looks very interesting and quite similar to what I want to do, the CP (Component Protection) looks a little worrying though - looks like I will have to do some research on that as well !
    Thanks Again
    Lyndon
  8. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Apr 2009
    Surrey
    172 Post(s)
    Thanks Again
    Lyndon
    I have the Kufatec AMI (identical to the OEM one) installed in my C7 and it came with a dongle to do the coding so I would think if coding is necessary then they will include a dongle
  9. Re: Is DAB Retrofit Possible on 2010 / 2011 A6 Avant
    Jul 2011
    Near Uxbridge
    Hi..
    It's a piece of cake once you have all the bits to do the retrofit. In the end I used an external aerial as I couldn't get the wires to attach to the aerial in the window...it also removes the need for the signal amplifier.
    No coding was needed...just CP removal.
    I'm in Egypt at the moment but if you need to ask anything I'm back at the weekend!
    Neil
    Sent from my HTC One using Xparent Red Tapatalk 2
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  1. Replies: 30
    Last Post: 14-09-2016, 10:26 PM
  2. 2012 Passat RNS 510 without DAB, how can I retrofit DAB?
    By gtx2010 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 29-10-2013, 12:49 PM
  3. Question Retro fit DAB radio to a 2011 VW Polo, can this be done?
    By roosevelt1st in forum Polo - Derby - Lupo - Fox
    Last Post: 09-06-2012, 01:11 AM
  4. A6 DAB retrofit
    By RickB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-04-2007, 12:18 PM
