Thread: Rear door unlocks - but doesn't lock again?
  1. Rear door unlocks - but doesn't lock again?
    Jul 2009
    Norwich
    I have a 2004 Passat estate and noticed that one of the rear doors does not lock with either the remote
    or using the key, but the other three doors do.
    At the moment the door will lock manually by pushing the button down on the top of the door.
    Has anyone got suggestions where I should start to look?
  2. Re: Rear door unlocks - but doesn't lock again?
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Its either the wiring to the rear door or the door lock module. Is it passenger side or drivers side? I ask this because I have a passenger side module for sale on ebay. One of the easiest way is to remove the door trim and metal door support. Unplug the wiring to the module and then plug the wiring to the new module. If it works then swap the module. If it does not work then its the wiring.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Re: Rear door unlocks - but doesn't lock again?
    Jul 2009
    Norwich
    Hi. Typically, its the drivers side! Went to have a look at it last night. Seems to be okay now? Suspect it will reappear though
  1. Replies: 0
    Last Post: 07-02-2012, 12:25 PM
  2. Please Help rear door wouldn't lock from inside (using 'lock' button)
    By angermayer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2011, 07:58 AM
  3. Central locking unlocks all except rear door drivers side
    By mattym in forum Bora - 1998 - 2005
    Last Post: 22-04-2009, 01:39 PM
  4. Remote now only unlocks driver's door
    By willharrison in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 07:30 AM
  5. Passat Boot Lock doesn`t Lock
    By Graeme H in forum Passat - Archive Topics
    Last Post: 10-03-2006, 11:34 AM
